I tryed to download my printer software and now my computer keeps shutting down evertime i try to open up a program
    Novelist:
    Champion:
  • 227 Answers
Boot into safe mode (Keep hitting F8 until the boot option comes up)
In safe mode go to Start, Programs, Accessories System tools
Select System Restore
Pick a date before you loaded the printer driver software
The computer should be fine now but without the printer driver
Find a printer driver from the manufacturer that matches your model and operating system
Install the printer driver
Hope this helps
Posted on Oct 13, 2010
I CANNOT PRINT ANYTHING SINCE I'M BUY THIS PRINTER. WHEN EVERY I'M TRY TO PRINT SOMETHING IT'S SHOW NO :2 ON THE PRINTER THEN IT'S KEEP SAYED ERROR 5100.WHAT IS MEAN...
Did you download the software from the disc that was included with your printer? If it didn't come with a disc go to the Canon web site and find your printer and download the latest software from them then after you have done that, shut down your computer, start it back up again and try to print, that should solve your problem, but make sure you reboot after installing software so that it can update your system....
Oct 08, 2013 | Canon Office Equipment & Supplies
I just installed gimp 2.6.11, but when I try to open it, it opens only halfway than shuts down right away. I had an older version in here which worked perfectly. Help would be welcomed! Thanx
Try restarting your computer and then try to open the program again.
If that doesn't fix it, Uninstall GIMP and re-download the program and install again.
If the problem persists after that, check CNET downloads for previous versions that would be compatible with your computer.
Mar 22, 2011 | GIMP GNU Image Manipulation Program
I have just bought and downloaded the discs a canon pixma mp270, whislt it worked ok, once I shut down my computer and then turned it on this morning it came up I needed to load a system disc of my vista...
This could be because the canon software is not compatible with Vista. Vista automatically takes a checkpoint before installing any software. So once the system is booted, restore your OS back to the good state. Follow the below steps to restore:
1. Goto 'Start -> All Programs -> Accessories -> System Tools 2. Click 'System Restore' 3. Click on 'continue' when prompted 4. Choose the second option "Choose a different restore point" 5. It will list the checkpoints taken when any recent software is installed. 6. Select the best date and continue.
IF the above didnt work, try to uninstall the software from 'Add or remove" programs.
Please come back and rate my solution, if it turn to be helpful. Thnx
Mar 20, 2010 | Microsoft Windows Vista Home Basic for PC
Connecting 2 HP printers to my computer
Ignore the error.
Disconnect both printers. Uninstall both sets of software. Download and install the F4210 software. Plug in the printer go through the steps and print a test page. Shut down the computer and disconnect the printer. Reboot and download and install the second set. Connect the printer to a different USB port and complete the installation. Shutdown, connect the other printer to the original USB and reboot
Dec 06, 2009 | HP Deskjet F4210 All-In-One InkJet Printer
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Aug 18, 2009 | HP Office Equipment & Supplies
Kodak printeresp5 crashes and am not able to get back printing
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.. keep me posted.
May 10, 2009 | Kodak ESP 5 Printer
Software loads but HP solution center won't open
I would recommend un installing "any" HP software first, then download and install the latest driver from HPs site. You could could also try running the installer with all startup apps disabled incase there is some conflicting software. You can do this by typing in "msconfig" from start > run. Once open select "selective startup" then uncheck "load startup items". If you resort to this be sure you have unintstalled all HP software first as some HP software does run at startup. Also be sure to re-enable the startup items after troubleshooting.
Apr 15, 2009 | HP Officejet Pro L7680 All-In-One Printer
The oct shuts computer down
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C7280 All -In_one---can't get it to scan
1. Tried opening HP Solution Center
2. Try scanning using the solution center
3. If you still unable to scan using the HP Solution Center try to check if there is Digital Imaging Monitor in the lower part of your screen. If you can not see it download the scan diagnostic utility.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-45265-1&jumpid=reg_R1002_USEN
Note : do not save the software. Just run it. If it still unable to solve your problem.
4. Click on start and go to control panel. Under control panel go to scanners and cameras. Try testing the scanners and cameras. If it works try restarting your computer and then try to scan.
5. Try to scan using a shorcut from the hp software. Right click on MyComputer and open it. Open C drive and go to ProgramFiles. go to HP and then go to bin folder. Under bin folder look for hpqscnvw.exe and try scanning using the software. If you are satisfied using the program you can put a shorcut of it in your desktop. If you are unable to scan using that program.
6. Uninstall the software using the CD. Do not use the uninstall button on the cd software. Once the installation screen would come up just click on exit. Open MyComputer and then explore the CD software. Under the CD look for the "util" folder and under it look for "CCC" folder. If you are connecting the printer using a usb cable unplug it. Then uninstall the software using the Uninstall l1, l2, l3 and l4. After uninstallation put a check mark on restart later and click ok.
7. Close all the programs you have open.
8. Click on start and then Contro Panel. Go to Add/Remove Programs. If there is an entry for the printer software uninstall it. After uninstalling it close the programs being opened.
9. Click on start and then Control Panel. Go to printers. If there is an icon for the printer delete it. Right click anywhere in the printer folder screen and then select server properties. Click on port tab. If you see their a port for your printer delete it. Click on the driver tab. If you see their a driver for the printer delete it.
10. Close all the programs.
11. Remove registry entries for the printer
11a. click on start and then click on run. Type in there regedit.
11b. create a back up registry by right clicking on computer and select export. The file name for the backup registry should be HPBackUp and save it on your desktop.
11c. After creating a backup registry. Delete printer entries. Click on the computer. Then Press and hold CTRL button and then f. A new window would open up. Make sure that in that window only the first and last option have a check mark. On the search box type in their printers. and then press enter. It will search for printer folder and under printer folder if you see there an entry for the printer delete it. Keep searching "printers" folders until you have completely remove the entry for the printer.
12. Download the software of your printer in the website. www.hp.com/support
13. Install the software again
14. Try scanning afterwards using the HP Solution Center
Aug 10, 2008 | Office Equipment & Supplies
I,m trying to get free downloads for mylexmark z715 printer.
Click the link below. Download your printer software & drivers for Windows Vista. Please read File Details before downloading files. Creat a folder on your desktop. Name the folder Lexmark Z715. Save your download to this folder. If you have a CD writer your can burn this download to a CD. Lexmark does not sell this software on CD.
http://www.downloaddelivery.com/en/cpddrivers/441.html
Before you install the Z715 software. Power off the printer, open Control Panel & open Add/Remove programs. If your printer & it's software is listed, try to uninstall programs. If the uninstall fails than just run the downloaded Z715 driver & software.
Good luck & best regards.
please vote...
Mar 06, 2008 | Lexmark Z715 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
