Question about Shure SM58 Professional Microphone
Our band's vocalist has an SM58 beta radio mic. This is now the third one he has used, The first got full of spit and sweat and the sound gradually deteriorated, so he replaced the head. When the same thing happened with the second, he intended to do the same but for £3 extra he could have a new body too, so replaced the whole thing. The first two gigs with this went fine but three out of the last four gigs, two songs from the end, the bottom end has dropped out, making him sound he was singing in a bucket! The second time it was through someone else's PA so it's not a mixer/PA problem. Had it back to the store he got it from, they put it on test for 8 hours without changing the batteries and can't find nothing wrong. Any suggestions or similar issues?
  • thegoodmachi Oct 29, 2010
    Already tried that via the shop where it was purchased after it happened again after 30 minutes. The local Shure office were most unhelpful and basically said they don't go wrong in this manner! The next gig I swapped the head for the old one and no problems, apart from the fact it sounded a bit dull due to the problems mentioned in the original post, the removed Shure's suggestion it was suffering with interference . We have now ditched the Shure altogether and got a Line 6 radio mic and I have to say it is a league above the Shure and I would recommend to anyone planning to buy a radio mic!
    Sergeant:
  • 334 Answers
In my experience, the sure Radio stuf is not much cop unless you spend into the 600 mark and above. Their hardwired stuff like the 57,58s and beta range are bomb proof and are good workhorses.
I am personally a fan of the Senheiser ranges of radio stuff. Again, BOMB PROOF
Posted on Oct 03, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact your local Shure office. They will be able to help you troubleshoot and are most familiar with the product.
Posted on Oct 29, 2010
I have 2 sm58 radio mics these are very old when i switch off the mic handset it gives an ear spiltting spiltting sound like consant interference can any one help
Sounds like your wireless transmitters (mic) and receivers have drifted from their original factory set frequency. Also, older units may fall into the "illegal " 700Mhz frequency band and should not be used...
http://www.fcc.gov/encyclopedia/wireless-microphones
Feb 17, 2013 | Shure SM58 Professional Microphone
HOW DO I SYNC A SHURE LX WITH A BETA 58A
I'm missing something here...Shure LX is wireless system with option of SM58 head...Beta 58A is a corded mic???
Owners manual...
http://www.fullcompass.com/common/files/16770-lx%20wireless.pdf
Feb 05, 2013 | Shure LX-2 With SM58 Professional...
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
I have recently bought a Berhinger PMP4000, I set it up with an SM58 through mic input 1 but can get hardly any volume ? Please can you advise where I may be going wrong ? I am running the power amp with 2...
Things to check: You are using XLR mic cables... You have the speaker switch in the uppermost position A and B mains... the mute for that channel is off... For an SM58 the TRIM for that channel will be at about 3 o'clock to near full on, depending on vocalists voice strength... The CHANNEL fader will be at around -5 to 0 (75% up)... The MAIN fader will be around 50 to 80% depending on how big a room you are in. I assume the Peaveys are on separate channels IF they are 4 ohm speakers. The A and B outputs have a MINIMUM load of 4 ohms. With 4 ohm speakers you can get 400 Watts per side... about 250 Watts with 8 ohm speakers. DO NOT SET SPEAKERS to bridged mode... ALSO please read my tip on Fixya about a hazard of channel A polarity if you use 1/4 inch plugs on the ends at the speakers. The SLEEVE of channel A is the HOT, not the tip and grounding the sleeve can blow the channel A amp.
Aug 21, 2011 | Behringer PMP4000 / B212XL Mains Monitors...
Distortion on vocal reproduction on Vocalist Live 2. Even with input volume down to minimum a loud vocal performance produces distortion on single voice and harmony output.
You need to check the actual signal levels to make sure they are within the specs for the unit. The mic input is low impedance. Your mic should be like a Shure SM58 or equivalent. The output is fairly high... up to +14DB which will require you to turn down the trims on a mixer this runs into or set a -20Db pad at the input. I suspect your distortion is from the device output to the mixer input. It is VERY important that the mic does NOT "hear" the speakers as the feedback loop resulting will be mass distortion. The guitar should also not "hear" the mains.
May 07, 2011 | DIGITECH VOCALIST LIVE 2
My sm58 beta distorts.Is the mic element hard to change out?
If you know how to use a soldering iron, the element is easy to switch out. However, it is probably less expensive to send the mic to Shure. That is the cartridge might cost more than the flat fee repair charge that Shure Service charges.
Jun 18, 2010 | Shure Beta 58A Professional Microphone
Cannot get the microphone to work on rockband for ps2
A plug your stick remote control in this will let u control mic hit x botton on remote
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
Play rock band for wii without mic, drums and guitar only?
Don't use the controller to navigate, that's the vocalist's controls. Go in and out of menus with the instrument you intend on using, don't use the controller.
Dec 26, 2008 | Nintendo Rock Band for Wii
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
Shure SM58 Professional Microphone Logo
79 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
