Thing Coloured lines on the monitor of my laptop.
Thank you so much for your reply to my post about three lines on my Laptop. Can you suggest where best it would be to leave the computer to be fixed. I wouldn't attempt to fix it myself. In the first instance I have very little if any technical knowledge of computers and secondly even if I could go by what you've suggested I have a disability which doesn't allow me to keep steady enough to hold screwdrivers or to work with fine wiring. If you happen to live in Ireland and happen to know where best to have this problem sorted out, perhaps you would let me know. Thanks. Paddy Doyle Website: www.paddydoyle.com
    President:
  • 2,712 Answers
Do you live in Dublin?
There is a place called Laptop Repair on Lower Clanbrassil street. Or else, there is one in the Grafton Street Mall on the 3rd floor, and another in the Moore Street mall...
Posted on Jun 02, 2008
Vertical screen lines
I suggest that you check the connection of the motherboard and your computer's screen because it has something to do with it. Or if resetting the connection won't do anything then I suggest that you let a tech check it.
David
Jul 18, 2013 | NEC Computers & Internet
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Jun 03, 2012 | IBM ThinkPad T40p 2373 Notebook
Coloured lines all over the screen on laptop
Good Afternoon,My name is Abhinash you can call me at 9085573251 for any problem.
I think your laptop is fallen or thrown,the solution of it is to change your LCD screen.Thank you! give me rating.
Aug 31, 2011 | Acer Computers & Internet
Ls developed vertical coloured lines which cover half the screen, I have attached an external monitor which works perfectly any ideas how the laptop screen can be repaired
I would checkout ebay for a replacemet screen and just change it. If you get a screen and then get lost, post another question and we can help you take the laptop apart and put it back together.
See www.insidemylaptop.com there may even be your model laptop having a screen replaced. They are all fairly similar to work on.
Hope that helps.
Mar 06, 2011 | HP Pavilion dv9000z Notebook
We have a Sanyo ProxtraX multiverse projector. We have used it a number of times but recently, it will not see the laptop. It turns on but cannot find the laptop signal. I have tried different laptops...
Have you tried the "Function and F key" trick? On most laptops it's the F6 key but on your unit look for a picture/graphic of a computer screen...or maybe text saying, "LCD/Monitor". To activate this function you must press and hold down the blue "function" key and also press the F6.
The F6 key has three states...1 - only laptop screen, 2 - only external monitor (video projector), 3 - both the laptop screen and the externally connected monitor and/or video projector.
Nov 08, 2010 | Office Equipment & Supplies
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
Vertical coloured lines on Fujitsu Siemens Amilo laptop
u screan is damaged
u must replace the screan with a compatible one,
Feb 21, 2010 | Fujitsu Siemens LIFEBOOK N6010 PC Notebook
Coloured lines
This is a sign that your screen or your video card is going bad. to test which one you need to connect it to a second monitor and look for the lines. If there is lines on both it is your video card, if it is only on the laptop's screen then it is the screen.
Dec 18, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My acer travelmate has coloured lines all over
I suggest you post your problem on the following forum. It appears they have active participants and they'd be more apt to have heard or had this problem before.
http://forum.notebookreview.com/forumdisplay.php?f=22
Sep 25, 2008 | Acer TravelMate 290 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
