Question about Texas Instruments TI-83 Plus Calculator
There are vertical lines on the screen that make reading it difficult
    Sergeant:
    Champion:
  • 387 Answers
It could be that the ram is full
2nd, +, 2, 1, delete what you dont need
i hope it will help
if you want to fix the Calculator let me know
ecrdn@yahoo.com
Jack
Posted on Oct 14, 2010
Vertical blue lines onscreen on the right side . Happens no matter what input including menu.. they appear over the menu . It's a Toshiba regza.
Vertical lines on an lcd screen are caused from the solder joints on the edge of the lcd panel coming loose. You can verify this by pressing on the edge of the screen above the lcd and the lines vanish. The fix is to either wedge something behind to hold pressure on it, solder it (which is difficult to do) or replace the screen.
Feb 19, 2017 | Toshiba Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vertical lines appear on my Thinkpad T30 screen, making it difficult to see or read anything from the screen. What can/should I do get this problem solved?
Try Pressing and holding different parts of the screen see if image sticks if not this means your LCD screen is bad and you should replace it.
Sep 12, 2011 | IBM ThinkPad T30 2366 Notebook
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical Lines in Monitor
If the lines are only on your laptop screen, it is generally the display IC on the LCD panel.
When plugged into an external monitor and you still see the lines, it is the video memory on your laptop.
Dec 23, 2008 | HP Pavilion dv8000t Notebook
Blue Vertical Line on my laptop screen
Does the line still appear if you plug it into an external monitor? If not sounds like your laptop screen has developed a fault, unlikely to be related to what you did with your camera just coincidence. The only way around this would be to replace the laptop screen. Not an easy job but not too difficult if you can find the same screen for sale on Ebay for example. Either that or replace the laptop and sell the old one on ebay for someone else to fix. Hope that helps Chris
May 22, 2008 | Toshiba Satellite Pro 6000 and 6100 14.1...
Vertical lines
1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
Feb 27, 2008 | Brother IntelliFax-2820 Laser Fax
Vertical line on screen
It sounds like you have a bad cable coming off of your Plasma Screen that goes into one of the buffer boards or a bad buffer board (Hopefully the latter which is easily replaced but most likely not!) I have run into the same problem and there is an IC made into the cable that goes out and would be very difficult to repair if it is even possible.
Nov 11, 2007 | RCA Scenium PHD50300 50 in. Plasma...
Texas Instruments TI-83 Plus Calculator Logo
327 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
