Question about GE GSS20IEP Side by Side Refrigerator
Frequently the ICE portion of the dispenser doesn't want to work. When the arm is engaged the light goes dim but nothing else happens. I tried opening the dispenser door by hand but no ice. I used to be able to switch the ICE choice to Crushed and then back to Cubes to trigger the dispenser. The water portion works fine.
  • b05bbrooks Oct 14, 2010
    I guess my problem wasn't clear. The ice maker works fine. It's just the lever that releases the ice doesn't always open the ice shoot. When this happens you can play with the lever and eventually the circuit kicks in and dispenses ice. I'm thinking maybe there's a problem with the electronic board?
    Genius:
  • 1,478 Answers
If your ice maker is not producing any ice at all, it could be due to various reasons. Firstly, check the right side of ice maker for a wire. The wire will be in an erected position, if the machine is turned off. In such a case, lower the plastic lever present in there or the wire directly if there is no plastic lever. This should be enough for your ice maker to start functioning once again.
There could also be a case of blockage in the ice maker fill tube. If this is the situation, use a hair dryer to melt any ice stuck in there which is causing the blockage. Replace the tubes if necessary. Check the ice maker assembly for any cracked up or broken parts. Especially check the gears and plastic arms along the ice rake, as these are more likely to break down compared to other parts. Replace them if needed.
Take care.
Posted on Oct 13, 2010
  • Jimoh Adeleke Muyideen Oct 14, 2010
    Sometimes, even though ice is formed perfectly fine in your ice maker,
    it does not eject out the trays. To solve this problem, you need to
    check the ejector gear and motor for any fault, and replace them if
    necessary. Also test the thermostat and ice hold heater in your
    refrigerator as the problem could be because of these parts
    malfunctioning.
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
My SSH25KFRFWW doesn't dispense ice or water when you press the lever.
Sounds like you soft reset the pcb when you switched it off. Probably just a glitch. Keep an eye on it for a few days, and check everything for the baby is kept properly cool etc. Good luck!
May 15, 2012 | GE Refrigerators
Hooked up water, which dispenses invariably, but ice won't dispen
Remove the ice bin , and behind it , on the rear wall ,use a screwdriver for leverage , between the dispensor " arms " , to see if the arms turn the motor fairly freely and not jammed . If it seems jammed , use a hair dryer aimed at the center of the arms to heat up the motor shaft to melt any ice possibly freezing it . No disassembly required .
If the arms turn fairly freely ( not jammed ) , then the main control board behind the refrig , is the problem .
Apr 13, 2010 | GE Monogram ZFSB26DRSS Stainless...
When pushing ice dispenser on GE side by side light dims and nothing happens
sounds like a large current draw is causing the light to dim most likely the cause is a build up of ice around the auger motor or the auger is seized.
Mar 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not working but are getting water from dispenser.
IF YOU HAVE THE SAME FREEZER AS MY MOM HAS THEN I MAY CAN HELP YOU OUT. FIRST OFF WHEN YOU OPEN THE FREEZER PORTION (SIDE BY SIDE STYLE) YOU WILL SEE THE ICE DISPENSER. TAKE THE PART OFF WHERE IS SHOWS YOU: TO MAKE ICE MAKE SURE ARM IS DOWN AND TO STOP MAKING ICE RAISE ARM. THAT IS A COVER THAT WILL COME OFF WITH NO TOOLS NEEDED. ONCE YOU OPEN THIS YOU WILL SEE A METAL FRAME WITH A WHEEL IN THE MIDDLE THAT SAYS DO NOT TURN BY HAND. LOOK IN THE MIDDLE OF THE WHEEL AND SEE IF THE ROD IS BROKEN (FOR EXAMPLE MY MOMS HAD A CLIP ON THE ROD THAT WAS BROKE AND WOULD NOT ALLOW THE DIAL TO SPIN WHICH THEN MAKES THE ICE MACHINE SCOOP THE ICE OUT OF THE BOX) CHECK THIS WHEEL TO SEE IF IT IS STILL IN TACT. THIS COULD BE YOUR PROBLEM.
Feb 24, 2009 | Frigidaire PLHS267ZA Side by Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
GE GSS20IEP Side by Side Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
