Question about Brother MFC-5840CN All-In-One InkJet Printer
Printer will not start
LCD shows "unable to Init"
  • RightOn Oct 18, 2008
    YES!!! I have the same problem with MFC-5860cn
    "Unable to Init" error 48
    what a load of ****!!
  • Anonymous Oct 21, 2008
    i have the same problem
Had that problem also - only my ribbon cable was simply dislodged, and needed plugging in again
Posted on Oct 31, 2008
    Problem Solver:
  • 8 Answers
The flat ribbon cabling to the head is broken. You need to replace the head.
Posted on Sep 22, 2008
    Genius:
  • 3,587 Answers
Model number please..
Posted on Jun 01, 2008
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
ITTech7574
  • 85 Answers
SOURCE: init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
Posted on Aug 31, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc240c init 4F & init 5A
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
My brother printer MFC -J6510w cannot print because the lcd shows Unable to init. 48.... whats the best thing i could do?thanks ....
Hi, I used to scraych my head when ever my printer started its own silly language.
Now if when it starts, I remove the whole printer prog, then access website seeking supoort/downloads checkout/look for your printers specs and download latest update remember to click on the complete download prog. A pain I know it saves your hair, and stress levels. Good Luck.
Nov 01, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Printer unable to init. printer shows LAN ACTIVE
go to device manager and check for the port setting. Maybe the port driver is corrupted.
Try to uninstall and reinstall the printer software.
Check the lan connection cable by removing the connection and return it back. maybe it is just loose connection.
Try this as well
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Dear Guru,
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unknown error message UNABLE TO INIT. printer just stopped working
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
370 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
