Question about Sanyo Refrigerators
I have a Sanyo commercial refrigerator model# SRR-49FD. The display reads either 5H2 or SH2. The unit is not refrigerating.
  • 100 Answers
SOURCE: I broke all glass shelf of refrigerator. Where can I get them all? T T
you must contact www.us.sanyo.com
Posted on Oct 30, 2007
tech master
  • 120 Answers
SOURCE: LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
Posted on Oct 31, 2008
SOURCE: unit wont start display only shows (hrs)
ok i tapped out and called the repair man. he came and found out the main board is fried.
you have to change the board.
he charged me 350 total for everything.
so all you have to do is order the board and do it yourself.
board is around 200-250 i think
Posted on Mar 25, 2009
SOURCE: Refrigerator totally inop. 120 VAC & 12 VDC present. Unit is model # RM3662.
Yes, I did the same thing. I had a qualified RV repairman change out the board. He also told me there is a recall on this specific issue and that DOMETIC should pay for not only the board, but quite possibly the cost of the labor to repair.
Dometic phone # is 888-803-0013
Posted on May 29, 2009
  • 25 Answers
SOURCE: R-22 refrigeRATOR OPERATING PRESSURES
google refrigeration pressure temperature chart
Posted on Jan 24, 2010
What is the operating presesure and temperature for a r-134 commercial refrigerator
Those units are going to give you pressures corresponding to the surrounding area. A hot kitchen will get the head pressure up around 150-170 psi sometimes. The suction is going to be somewhere around 20psi give or take 10 psi either way. You can't trust pressure readings except for an indication that the compressor is pumping and you don't have a deep vacuum from a lost charge or plugged cap tube or blocked metering device. Always weigh the charge into the system. You cant be a hack hvac guy and help a guy by putting gas in his refrigerator. Commercial refrigerators are pretty touchy and don;t like to shut off if they don't have an exact charge. Don't take my word for it call True in St Louis they made the thing. Hope this helps and good luck.
Sep 17, 2014 | True T-49 Side by Side Refrigerator...
Code 5H2
sh means sensor short and 2 means sensor number 2
Dec 17, 2013 | Sanyo SRR49FD
Error code sh2 on a Sanyo srr-49fd
SH2 means sensor number 2 is shorted
Aug 03, 2013 | Sanyo SRR49FD
Sanyo SRR49FD reading SH2 what does it mean?
Nov 16, 2011 | Sanyo SRR49FD
Amount of refrigerant that carries this freezer is 1.6 pounds? "
Those freezers utilize R-404A refrigerant. The amount of refrigerant will be displayed on the data plate on the inside of the unit usually on the left inside panel. It will have the type and weight of refrigerant...
However, yes, 1.6 lbs sounds about right for those models.
Jun 06, 2010 | True 52 cu. ft. / 1472 liter Commercial...
Looking to buy a condensing fan blade for a federal industries display unit
go to a heating/plumbing/air-con place or elect supply with unit number or model number off fan-if have old damaged on not better can use to compare for replacement with a universal unit
Oct 05, 2009 | Federal Industries (CGR3642) Commercial...
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Refrigerators Logo
225 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
