Question about Canon PowerShot S1 IS Digital Camera
Pink pictures The pictures started having a pink tint to them. The last time I turned the camera on the screen blinked then went black.
  • john brad Jun 14, 2008
    Same problem, when i take pictures outside, the whole pic is pink. Inside or when the light is not bright, or when i use blitz, the pic is ok. The problem apears only in bright light, specially outside.
    Scuse-me for my english. Thank you !
  • corrine2 Jun 21, 2008
    Me too! I have a Canon Powershot A70, and am getting some pink images or missing images with white lines running across the view finder. Thanks for the post. I'll contact Canon.
    Corrine
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jun 03, 2008
Yellow pink tint screen
Have you tried set-up on the remote? Do that choose picture and adjust the brightness.
good luck
kolbrun
May 03, 2014 | LG 42LC2D 42 in. LCD HDTV
Black screen web camera
COULD POWER TO THAT CAMMERA BEEN CUT OFF ?
QUICK TEST AT NITE LOOK CLOSELY AT CAMMERA LENS SEE IF YOU SEE A LIGHT PINK/RED TINT TO IT, no THEN POWER IS OFF OR UNIT IS DEFECTIVE
Apr 20, 2014 | Lorex Home Security
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
My sister took my camera out with her to a convention, then when I was about to take a picture last night, the screen was strongly tinted bright pink and when I take a picture, it's tinted green and pink....
If the camera was exposed to very bright light it is possible to have the CCD/imager damaged , There can be a resetting, remove battery off for few hours and set.
If the fault stays it will be better to seek an opinion than to open the camera.
Sep 26, 2010 | Kodak EasyShare C633 Digital Camera
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
Canon powershot S410
a pink tint CAN be removed in Photoshop or picasa.
Check the settings in your camera. it could be set to "sepia" under effects.
Jul 23, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot S1 IS Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
