Question about Lite On LVW-5005 DVD Recorder
Liteon lvw5005 is there a firmware update that works
Does not play back it own recording and know take long time to load blank disc
is there a firmware update it can fix
Drummernick
  • 440 Answers
SOURCE: liteon lvw5005 began to gouge brank new disks. got replacmnt-after awhile same problem
try go web site do firmware update to read latest disk buddie
Posted on Feb 10, 2008
SOURCE: LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
Posted on Mar 15, 2008
  • 39 Answers
SOURCE: i have a liteon 5005 dvd recorder and it tells me
you must use the proper recording disc for formatting compatability of your unit. i.e. r+/r- confer with owner manual for recommended discs mch
Posted on Mar 09, 2009
  • 16 Answers
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
I have same problem like you, i replace it to a new Lite-On DH-20A4P, it work perfectly, good as new.
Posted on Aug 12, 2009
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Lvw5005 recorder
Go to www.local.com and search for a repair service.
Dec 22, 2007 | Lite On LVW-5005 DVD Recorder
How do i install a new firmware (UPDATE) TO FIX PROBLEM THAT MY DVD RECORDER LVW-5045 DOES NOT READ BLANK DISCS, THE RECORDER HAS NO COMPUTER CONNECTIONS TO CONNECT IT TO MY COMPUTER
Reference: http://www.liteonit.com/global/index.php?option=com_content&task=view&id=25&Itemid=103&limit=1&limitstart=1
You could change brands of "blank" disks, until you find one that it can handle.
Or, you could disassemble the LiteOn device, remove the DVD-writer, connect it to a computer,
verify that it does read/write while connected.
If it is OK, then update the firmware, disconnect it from the computer, and reimplant the DVD-writer, and reassemble.
Mar 03, 2011 | Computers & Internet
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
Sep 05, 2009 | Electronics - Others
LiteOn DVD Recorder is not properly working
If you wish to get some details; visit the site linked here. Pull up older posts.
Sep 28, 2017 | Televison & Video
DIVX Playback problems
I just checked the support site on Samsung.com. There have been two firmware upgrades issued on this product.
Click on this link for instructions and downloads
Jul 15, 2008 | Samsung DVD-R155
Lvw5005 recorder
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Feb 25, 2008 | Lite On LVW-5005 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
87 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
