Question about Simplicity Denim Star SW210
Simplicity denim star SW210 will only allow a few stitches to be made and then the needle gets caught down into the bobbin area. I have tried different needles and quality thread. I have cleaned and oiled the machine as recommended. Do you have any other suggestions? loriecalhoun@yahoo.com
Bottom thread is getting bogged down and stops working, I cleaned and ioled it and it still doing it.
Posted on Aug 15, 2012
2 Suggested Answers
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
How do I do a simple timing on my SW210? The mechs are catching in the bobbin area and is breaking, more like cutting, my upper thread.
sounds like needle /hook timing is out
with the needle all the way down and is just about to come up the hook of the bobbin case should be just about at the eye of the needle and just above the eye of the needle
the needle should be in so that the groove in the needle is facing away from the hook and the small cut away is at the hook
timing is affected by loosening the screw on the needle shaft crank arm and adjusting the shaft up or down to position the needle correctly in relation to the hook
the condition of the thread is important as old thread will laminate and the hook will split the thread
May 23, 2015 | Simplicity Denim Star SW210
Wheel will not turn on my machine
Several things can keep your machine from turning. Thread can be jammed in the hook area, around the shaft by the hand wheel as well as near the take up lever. It is also possible you can have the machine in bobbin wind mode. That would be the first place to check.
Start with removing the bobbin then the bobbin case or bobbin basket.
Try to move the hand wheel back and forth as you do this. Then remove the cover that holds the hook in place. Remove the hook if this does not fix your machine you may need to take it in for service.
Oct 13, 2014 | Simplicity Denim Star SW210
Free owers manual
your question is put under the sewing machine name of
simplicity denim star sw210, so that is the links I'm going to supply
for a manual,, but the manual is not free, I don't know where you can
get one for free
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw210.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-denim-star-sw210-download.aspx
Aug 06, 2012 | Simplicity Denim Star SW210
Not completly threading or something
i was told this is a timing problem
Feb 26, 2010 | Simplicity Denim Star SW210
The bobbin mechanism fell out when I opened the bobbin area door
Once you have the bobbincase off the hook lay the hook in so it fits good. Then you can lay the round piece in and there should be a small tip that fits into a notch. Then you snap on your bobbincase.
The trick is to put the 3 parts in separatly.
Hope this helped.
Rick
Mar 22, 2009 | Simplicity Denim Star SW210
Winding the bobbin - Simplicity Denim Start SW210
you have to move the lever so as to engage it to the wheel. Don't thread the thread all the way to the needle. only lead it around the top position. Disengage the small wheel on the right so that the needle doesn't go up and down.
Jan 06, 2008 | Simplicity Denim Star SW210
Simplicity Denim Star SW210 Logo
140 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
