Question about Brother MFC-8860DN Printer
My brother MFC 8860DN printer has an error showing: Rplace fuser. Does it have a fuser and where can I get it?
    New Friend:
  • 42 Answers
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
Posted on Oct 13, 2010
I replaced the fuser. How do I reset the fuser?
Replace Fuser Message and Reset Brother MFC 8480DN ...
? 0:46
www.youtube.com/watch?v=quGzXnDsZQA
Jun 27, 2012 - Uploaded by Kevin Gumpp Instructions on how to reset and replace the fuser on a BrotherMFC 8480 ... V?deo Recarga Toner Brother TN 580 ' MFC 8860DN ' DCP 8060 ...
Oct 01, 2015 | Brother Printer MFC L8850CDW Wireless...
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
Jul 10, 2014 | Brother MFC-8860DN Printer
Brother MFC 8660DN "Toner Error Reinstall Drum I got a new drum, new toner and still printer isn't working and show the error reinstall drum unit please help
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
Apr 04, 2010 | Brother MFC-8860DN Printer
Brother mfc 9880 fax/copier makes grinding noise and has paper jams
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
Mar 31, 2010 | Brother MFC-8860DN All-In-One Laser...
How reset fuse Brother MFC-8860DN Printer
fuser counter reset
press MENU - START - 088
LCD shows "PARTS REPLACEMENT"
go down with arrow till reset fuser?
press "SET"
done
Nov 21, 2009 | Brother MFC-8860DN Printer
Problem for Brother MFC-8860DN Printer How do i reset fuser count after replacement
press menu 7 3 2. this will bring you into the parts reset, and reset the fuser
How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
http://www.sharperminds.net/downloads/instructions_for_changing_a_fuser_gear_on_a_brother_printer.pdf
Hope you find this helpful.
Ed
Sep 07, 2009 | Brother MFC-8860DN Printer
Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Aug 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Nov 04, 2007 | Brother MFC-8860DN All-In-One Laser...
Brother MFC-8860DN Printer Logo
1,161 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
