VCR eats tapes
I have a VCR that I do not want to trash. I have lots of childrens tapes I want to be able to see. Is it cost effective to have this repaired?
  • surfsucks Mar 01, 2009
    I have the same problem its a Panasonic pv-8661
  • 4,234 Answers
Please supply the make and model number as each one will have replacement parts unique to the model and cost differing amounts of $$. Also, what is the specific problem that the unit is having?
Thanks,
Dan
Posted on Jun 03, 2008
I have a phillips combo tv/vcr working perfectly but when I insert a vhs tape it rejects and switches off. I have tried many tapes all working in my other vcr.the tv is working ok.
VCR ?? With the possible age of the device, there could be a lot of issues with grease that is old, belts that are stretched etc. A VCR senses tape tension in order to prevent eating the tape. Clean the unit and check all the belts.
Jan 28, 2017 | Televison & Video
Vcr is eating the tapes
THE VCR NEEDS REPAIRING.THE REASON WHY YOUR TAPE IS EATEN THE TAPE PATH NEEDS RE- ALIGHNMENT AND LUBICATED AS THE HEAT FROM THE TV WOULD OF DRIED THIS OUT.
May 02, 2010 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Emerson EWD2004 vcr eating vcr tapes
This is caused by mechanical problems in the VCR. Depending on the age and maker of the VCR, the take-up reel in the cassette is driven by a gear, a belt or a rubber wheel. This isn't happening properly in your VCR, so the tape is piling up inside. Given the low cost of replacement combo players (I don't think you can find just a VCR these days), it's not worth having repaired. You can expect to spend $60 to $100 on a repair for this kind of trouble, assuming there are even shops still willing to take the machine in.
May 13, 2009 | Emerson Televison & Video
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Picture blinking on a Sharp Quos HD TV
A lot of times with recorded tapes, the tape that's inside doesnot work well with vcr s. I have had this problem with old and new vcrs and if you keep trying then the device will eventually eat the tape.....
Apr 10, 2017 | Televison & Video
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
