Question about Woods Upright Freezer MU07W
Can I transport a woods upright freezer in a horizontal or close to horizontal position?
    President:
  • 2,651 Answers
Not the best way to do it, but if you must, just when oyou getit to its final destination leave standing up for at least 24 hrs before restoring power... you dont want oils from compresoor circulating through unit.. give it the full 24 hrs
Posted on Oct 13, 2010
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
Door not staying closed
most freezers use magnets to keep the doors closed
May 25, 2014 | Woods Upright Freezer MU07W
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Jan 19, 2012 | Amana Freezers
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO MEXICO IN A HORIZONTAL POSITION SO NOW WHEN I RE-CONNECT IT, ITS INTERIOR IS COLD BUT ITS EXERIOR WALLS ARE SO HOT...?
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Aug 27, 2009 | Frigidaire Freezers
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Jun 26, 2009 | Freezers
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Woods Upright Freezer MU07W Logo
308 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal De
Are you a Woods Freezer Expert? Answer questions, earn points and help others
