Question about Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator
At first the entire unit was not cooling on either side (before that we noticed that it was making ice very slow) I found the evap fan motor was not coming on and the coils were about half way frosted over. I just removed the motor and reinstalled it (the old one) and then it worked. Now the Freezer and Refrigerator is too cold. I have both controls turned almost to zero. The damper door seems to not work. How can I test this? Could the problem be somewhere else?
catriver
  • 878 Answers
SOURCE: replaced mother board now damper clocsed
rip, couple of checks to do: On the main board, connector J3. On the harness you should have 400 ohms on J3-1 (yellow) to J3-2 (red/black) and 400 ohms on J3-3 (white/brown) to J3-4 (blue yellow. Same values should be at the damper motor. If you don't have those values, damper motor defective. One other check, you have 10 seconds to do this on power up, so get some help. Plug in the refer. Check for 6 VDC. DC voltage now from pins J3-1 to J3-4. If you don't have this it's the board. If you do have this and the dampers not working, replace the damper. Catriver.
Posted on Aug 16, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Posted on Jan 11, 2008
  • 958 Answers
SOURCE: Kenmore model 59675502400
if the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
drcool
Posted on Aug 26, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
GE GSS201EMDCC Fridge and freezer not cooling.
there is probaly a "clixon" in the unit that senses the temp of the evap. if the evap does not get down to a certin temp the fan will not run. this makes it so you do not have ice crystals all over the freezer. matters on model. also sounds like the fridge might be short on gas.
Apr 08, 2009 | GE GSS20IEM Side by Side Refrigerator
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Mar 05, 2008 | Refrigerators
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
