Question about Samsung DV218AEW Electric Dryer
Rumble thumping noise even when empty - Samsung DV218AEW Electric Dryer
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 13, 2010
Load noise when washer spins
can you discribe the noise is it a rumbling sound or a thumping sound
Nov 29, 2011 | Kenmore HE2 Plus Front Load Washer
My refrig is making a rather loud noise when the compressor kicks on low rumble
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
May 03, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Flashing pyramid of dots,
Your toner cartridge is empty. After turning it off then on again it is probably running for several minutes while making a light thump thump noise. This means it is trying to add toner but not getting any. You need to replace the toner cartridge or have it refilled.
Thank You for using Fixya.
Jun 10, 2010 | Sharp AL 1631 Copier
Washer makes thumping noise when spinning and belt jumps off
I suspect that the main drum bearings have failed.
Remove the belt, and from the front spin drum by hand, if it feels rough or is rumbling or noisy, then drum bearings have failed.
Can be expensive!!!!
Feb 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
My propane heater rumbles and thumps when turned on.
Sounds like you have a 2 speed pump. The heater needs high speed to operate. The noise is due to the low water flow. The water is actually boiling in the heater. Crank up the flow and that should solve your problems.
Dec 18, 2008 | Hayward H Series Propane Electronic...
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Aug 01, 2008 | Asko Dryers
Samsung DV218AEW Electric Dryer Logo
384 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
