Question about NEC Computers & Internet
Out of range displayed on monitor - NEC Computers & Internet
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ok..out of range..suggests something to do with a wireless set up? we'll need some better information here to assist.
    Problem Solver:
  • 33 Answers
Out of rang on a monitor has nothing to do with wireless.
Out of rang on a monitor means that the settings on the video signal are too high for it to show. The fix is to lower the video settings. You can start your computer in safe mode to change the settings if you don't have a better monitor to access it.
Posted on Jun 01, 2008
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Screen says out of range
I would say that the computer is trying to use a display resolution that the monitor is incapable of displaying. You may have to lower the resolution from the PC before you get a picture. Make sure you install the correct drivers for the monitor onto the new computer and use a different monitor to adjust the display resolution to a level that the monitor is capable of displaying.
Dec 15, 2009 | AOpen F2705 17" LCD Monitor
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Over Range
The display card resolution is set too high for the handling of the monitor, or the system board in the monitor is faulty.
Jerry G.
Jul 14, 2008 | Batesias BT-1501 (Silver) 15 in. Flat...
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Computers & Internet Logo
170 people viewed this question
Top NEC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
