Question about RCA D52W19 52" Rear Projection Television
Picture has 3 images, all different colors (red-blue-green) screen looks concave in the middle top & bottom
    Sergeant:
  • 233 Answers
I have the same exact problem! I have replaced the convergence board, and the power supply board (the one the AC cord plugs into) I have also resoldered the flyback transformer, AND checked the 3 fuses next to the flyback with a meter...and still to no avail.... I do have convergence and auto convergence available as options in the menu, and in the service screen, but on manual converge mode, the crosshairs will not move, and on auto convergence mode, it will strobe red once, then show a full red screen (concave at top and bottom) and go straight back to menu with no improvement! please help!
Posted on Jun 26, 2008
    Genius:
  • 1,030 Answers
This is what is known as convergence..(very common)... first question DO you have the "CONVERGENcE" option in your setup menu?.... if you dont there may be a special fuse issue... if not then more than likely it is what is known as convergence power supply issue. you have complete loss of convergence?
Posted on Jun 06, 2008
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Dec 17, 2008 | RCA D52W19 52" Rear Projection Television
Picture is concaved and all the colors are off.
you will need to get a convergence done and the resistors on the conversion IC's checked and bad ones replaced
electech
Oct 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
199 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
