Question about Stanley Tools & Hardware - Others
The drive that pushes the nail will not retract all the way .. only one nail can be fired then manually push drive up so another nail may be chambered
  • 43,501 Answers
There needs to be a bit of lubrication there...
spray the area with some WD-40 and let it soak...then place a few drops of light motor oil on the driver and then turn it upside down so the oil runs back and lubricates it...
Then it will work...
heatman101
Posted on Oct 13, 2010
Coilated framing nailer will drive 2 1/2 nails but gun jumps and only sets nail about 1/2 way in with 3 1/4 nails with full airline pressure.
Hi Paul,
The reason is that you are allowing the nail to "push" you off the wood when the tool fires. Probably you're using a very hard wood with a ring shank (Annular) nail. The best way of overcoming this is to push just a little bit harder down onto the tool before firing.
We see this quite often when people are just starting out with these tools, don't worry though, it gets better with practice!
Dec 31, 2014 | Air Tools & Compressors
Inoperable nail gun
replace trigger , sounds like your trigger is keeping the firing valve in the open position allowing air to push the driver down, and exhausting the air out of the top, could also be that the firing valve itself is worn or broken
Aug 08, 2012 | Air Tools & Compressors
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Driver does not retract after striking a nail
if its new warranty it,
otherwise all it should need is a rebuild kit . its just a bunch of orings and gaskets. pretty easy to do. take some pictures as you take it apart to help with reassembly.
Dewalt should have scematics online or ereplacements.com
Apr 08, 2010 | Dewalt D51844 Framing Nailer
After each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Mar 25, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Nails not feeding in
The unit need cleaning and oil. Possible a wix spring.
Mar 14, 2009 | Porter Cable-Cable BN200B 5/8-inch to...
Tools & Hardware - Others Logo
87 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
