Question about Sharp 25J-S100 25" TV
How to set up the Sharp 25j-s100 tv for satellite tv connection
Can this TV be hooked up to satellite?
If all u have is a screw on connector u will have to get a RCA converter which the round connector hooks on to and the Sat will plug into it and set the channel button on the converter to what the TV is.
Aug 29, 2015 | Sharp 25R-S100 25" TV
Snow on screen
If blue-back option is OFF, it is normal to see snow on screen, when there is no RF signal. This is not a fault.
Aug 04, 2012 | Sharp 25J-S100 25" TV
Input jacks in Sharp 25J-M100/ Pc to Tv cable
You can purchase an s-video to composite video connector to view your Dell computer's television output on your sharp CRT television, though the image will be a bit blurry because of the connection and CRT technology limitations, though streaming video probably can be seen just fine. An example of an s-video to composite video connector can be found here: http://www.svideo.com/svideorca.html
but you probably can find a cheaper priced unit somewhere else, maybe even at radioshack.
I hope this helps!
May 18, 2009 | Sharp 25J-M100 TV
User manual for a sharp cx5182 tv
where is the reset button on my sharp 19" tv it,s my front tv located on my rv.
Mar 09, 2009 | Sharp 25R-S100 25" TV
25' sharp flat tv aquos
your tv set has lose connection just reheat some lose connections possibly in power supply section, in the horizontal circuit, in the vertical section, in chroma circuit and if there is lose connection u can resolder it, but you must be careful not to short circuit the pins.
Jul 30, 2008 | Sharp 25R-S100 25" TV
Code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Jul 15, 2008 | Sharp 25J-M100 TV
SHARP TV - MODEL 25j m100
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Feb 21, 2008 | Sharp 25J-M100 TV
Digital or Not
The Sharp 25R-S100 TV is a standard NTSC TV with a 181-channel PLL tuning system....which means that it is not digital.
Jan 24, 2008 | Sharp 25R-S100 25" TV
Televison & Video Logo
62 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
