Question about Brother MFC 420CN All-In-One InkJet Printer
Printer MFC 420CN
My MFC 420CN printer states that there is poor line conditions and out of memory when I try to fax things.
    Guru:
  • 1,342 Answers
Click HERE to read previous suggestions to this problem.
Posted on Jun 01, 2008
Im trying to send a fax but it saids out of memory and poor line condition
This message show when temporary memory full fill because of too much pending command or execute command which hold printer temporary memory. So you need to clear or delete pending command from its memory then restart your computer. Thanks a lot
Nov 10, 2012 | Brother MFC 420CN All-In-One InkJet...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Poor line condition / out of memory when attempting to send fax
That is a problem with your phone line. Get a line filter from Radio shack and install it between your wall socket and the fax. This should solve teh issue.
Jul 08, 2010 | Brother MFC 420CN All-In-One InkJet...
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
When faxing it states NG: poor line condition/ out of memory
to solve this ... you need to have your phone company "condition" the line. Somewhere between you ant the CO (Central Office) there is/are come crummy (read Corroded) connections.
This may cost you ... inquire before you order the conditioning.
E-mail is more convenient ... consider instead of FAX
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
Error message for fax
not thing to do with your machine call your local phone comp they will take care of you!
Dec 11, 2008 | Brother MFC 420CN All-In-One InkJet...
I cant fax HELP!!!!
plz see www.brother.com choose your country and your mfc.
You will find an answer to this issue within the faq. In case there are questions left, plz contact brother hotline of your country.
Apr 15, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
293 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
