My Techwood 26832 HD TV isn't working properly. It just flashes between red, green and blue. I can't access the menu and none of the buttons respond. Do you know what the problem is and would it be expensive to fix?
5 Suggested Answers
  • 418 Answers
SOURCE: When you turn on the TV the screen flashes through
Sounds like it's in a service burn-in mode. LGs need a service remote to de-activate. Probably easy for a local LG shop.
Posted on May 03, 2010
snakehead
  • 1074 Answers
SOURCE: I have a Techwood 22884
plug it out of the current outlet for about a hour then plug in back then power..if that does not help take it to the tech for repair your microchip which holds the set memory is bad.
Posted on Sep 13, 2011
TODDAS
  • 431 Answers
SOURCE: techwood tv flashing colours
Check to see if test pattern is on, in the main menu.
Posted on Nov 28, 2011
gopakumarg43
  • 74383 Answers
SOURCE: My Techwood TV Flashing from Green to Red then Blue..
T'Con board fault.
Posted on Aug 11, 2012
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
Techwood tv flashing colours
Nov 27, 2011 | Televison & Video
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
No red when hooking up component cable for dlp hd tv. Only blue and green colors show on hd component input for charter hd cable box. Are there any internal adjustments that need to be made through either...
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
Nov 03, 2009 | JVC HD-61Z456 Television
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic N2750w flashing different colors on screen
did you get any answers? I have the same problem.
Jul 06, 2009 | Televison & Video
JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Nov 29, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Electro Med Services...
