Question about Seca 884 Certifiable Electronic Personal Digital Bathroom Scale
It shows Er:1:40, Ireplaced the batteries unplug it for a few and still showing Er 1:40. Would you please give a tip to fix my SECA 884 scale. thanks in advance E
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a SECA 884
Hi.
Reset the scale by removing and putting back in place the batteries.
After putting the batterieas back in the slot, perform procedure below:
Place the scale on a level surface.
Ensure that only the feet of the scale are in contact with the floor. The scale may not be in contact at any other point.
If an uneven floor (e.g. thick-pile carpet) contacts the base of the scale, push on the carpet feet supplied (see Fig. 5).
Here an online user manual.
Regards.
Ginko.
Posted on Nov 08, 2010
SOURCE: Hi i have a Seca
Hi, this error code indicates an internal processing error and unfortunately it means that you will have to have it repaired. Often it is the "Stress/torsion bars" in the weighing part of the scales but not always. It is simply a generic fault indicator.
The best way to undertake this is to contact the manufacturer and ask for instructions on what to do? They may refer you to an authorised service center, or ask you to return it to the manufacturer itself? If worried about costings, and who isn't, simply first ONLY ask for a "Quote" as to prospective costings and go from there as to repair or replace?
Accordingly i give you the manufacturers link below.
http://www.seca.com/
Posted on Sep 19, 2011
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
Error message
check where u put your machine that place should be well equally balance and check some point should the there backside of this for resetting the machine
Sep 20, 2013 | Seca 354 Dual Purpose Baby Scale
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
Have Seca 958 chairscales. Error on diplay : Er : 1 : 40 Please can you help as this error is not mentioned in the manual.
This is an EEProm error. Recalibrate the scale or write the correct EEProm data by service program
Mar 29, 2011 | Health & Beauty
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Seca 884 Certifiable Electronic Personal Digital Bathroom Scale Logo
115 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
