Question about Whirlpool LEQ9858P Electric Dryer
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
    President:
  • Whirlpool Master
  • 2,651 Answers
Does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Posted on Oct 13, 2010
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
