Question about Canon PIXMA iP3000 InkJet Photo Printer
I have a paper jam and can't get to the paper to remove it. Your previous expert did not give me information that helped. Thanks.
  • 4,323 Answers
Hi
Try removing the back panel of your printer and check for stuck paper. Turn off the printer and try and remove the paper. After this disconnect your printer from power and from back of the computer unit, then remove the cartridges and check for any paper stuck under the cartridges. If not then turn the unit up side down and shake the unit. This will help you to remove any small paper bits stuck. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 13, 2010
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Paper jam error but no paper
If you previously had a paper jam and you are getting this error, make sure there are no small pieces of paper left behind. The printer will detect this and give this error. If the machine is clean, try unplugging it from your outlet and then plug it back in. It should clear the error.
I hope this information helps you,
Thank you,
Nico
Jul 08, 2011 | Epson Stylus CX9400 Photo Printer
My canon printer is getting jammed, when it tries to run thru it goes on an angle to the left side and gets jammed, How do I fix this?
That means that there is something jamming the paper on the right side. Check to see isf there is some paper residue from a previous jam near the rollers.
Also do the following:
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Canon PIXMA® mini260 InkJet Photo Printer
My hp 7300 gives me a paper jam error at turn on and there is no paper jam. It will not go past that point even when I press ok.
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer’s recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more information and help from here.
Aug 25, 2010 | Office Equipment & Supplies
Printer paper is jammed. Is there a release?
is there a... what? you didnt provide additional information, and you left the question unfinished. is there a way to remove the paper? is there a solution? yes. the paper can be removed. but i dont have enough information.
Product summary The good: Improved photo quality over previous model; attractive design; large 3-inch LCD screen; easy-to-use Home Center software.
The bad: Poor quality build with several mechanical errors; average print speed; graphics quality still lacks definition.
The bottom line: The Kodak ESP5 is an attractive full color all-in-one printer, scanner, and copier, and casual photo enthusiasts will be happy with the watered-down editing software, but hard-core users should look elsewhere for a multifunction printer. The ESP5 is too expensive and suffers from too many mechanical deficiencies for us to give it our CNET stamp of approval.
you will continue to have these paper jams.
Jun 04, 2010 | Kodak ESP 5 Printer
Major Paper Jam on Dell 5110
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1. Turn off the printer.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.
If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. *
To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer. Preventing a printer paper jam As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer.
However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring. * If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. * Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. *
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. * Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. * Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 17, 2009 | Dell 5110cn Laser Printer
Hp psc 2175 paper jam
Here you will find links pertaining to paper jams with your model. Just click the best matching link and it will give you detailed instructions on correcting the jam.
Hope this helps. Please remember to rate this information.
Thanks
Jan 04, 2009 | Office Equipment & Supplies
Paper Jam
Some basic non-tech questions:
  • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
  • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
  • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
  • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
Nov 22, 2008 | Toshiba 2060 Copier
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
Canon PIXMA iP3000 InkJet Photo Printer Logo
20 people viewed this question
old marine
old marine
