Hello, and chance of finding a schematic on a rheem furnace
  • Charlie Howe
    Charlie Howe Oct 13, 2010
    Can you get me the model number?
  • daverun57 Oct 13, 2010
    whats the problem
  • 43,501 Answers
If you have a furnace the schematic is right on the inside of the bottom cover...or on the inside on the side of the top of the furnace....
A furnace will always have the schematic somewhere on the sheet metal...
heatman101
Posted on Oct 13, 2010
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Rheem gas furnace displayes 3 blinks, does not ignite.....3 blinks means???
Look inside the unit, the codes are usually on or near the schematic of the unit. Otherwise check the owners manual.
Feb 16, 2015 | Rheem Water Heaters
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
What is the blink code for Ruud 2 stage ac/furnace
on the board itself or on the schematic there is a legend that will tell you what the blinks mean. start there. its just a diagram that gives you the fault according to the number of blinks
Sep 29, 2012 | Ruud Heating & Cooling
How old is a ruud furnace model number ugaa- 08KC, ser. number RN3D104F18794988
Hello, The model number for Ruud/Rheem equipment is located in the 12-13 digits, these appears to be a 1994. I have seen some furnaces with an age older than when the home was built (a 1995 furnace in a home built in 2000), so good job checking the serial number. This gives you the age it was manufactured.
Hope this helps James
Apr 03, 2011 | Heating & Cooling
We just had new Rheem Natural Gas Furnace
Hello. yes there is a 2 second delay and when the conditions are just right you can smell gas. Although this is not dangerous or a health risk, you could run the exhaust pipe up in the air a few feet to get rid of the smell. Regards, Joe
Feb 25, 2010 | Heating & Cooling
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
My 23 year old Rheem furnace stopped working not long after installing a programmable thermostat. Is the thermostat the problem or the unit is just too old?
If you did not turn off the power to the furnace when you installed the new thermostat. There is a very good chance that you shorted the thermostat wires and burned up the transformer in the furnace. Or, if you're lucky, you may have just blown the control voltage fuse if there is one installed.
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
