Question about Ryobi Backpack Blower 25.4cc
Throttle bogs down engine when applied - Ryobi Backpack Blower 25.4cc
3 Suggested Answers
SOURCE: pb-413h echo back pack blower
This is usually caused by one of two problems. First, the exhaust may be plugged. Pull the screws out of the small screen in the exhaust and wire brush the screen. Reinstall and try again. I had one where some bee's built a nest in the exhaust, no tcommon though.
Second, teh fuel pump in the carburetor may be on its way out. It may provide enough fuel to run at idle but not at high speed. You may need a carburetor rebuild.
Posted on Feb 15, 2011
  • 1381 Answers
SOURCE: Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Posted on Mar 13, 2014
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
How do I fix keeway matrix/150 when throttle is given it bogs down and won't allow me to accelerate up to speed
That old gas had sediment in it and you need to remove the tank, fuel pump and filters and change them.
Jun 30, 2014 | 2009 Keeway Matrix 150
What causes a 1993 seadoo engine to bog down then take off, then bog down?
fuel mixing issue. A good tune up is recommended. Focus on the carburetor.
Jun 07, 2014 | Sea-Doo US Seadoo Sea doo pump off 1993 XP...
95 honda civic engine bogs down highway speed full throttle
is there a rattle under the car like the cat converter is bad when was the fuel filter last replaced
Apr 28, 2012 | Cars & Trucks
Engines runs ok on idle pulls away ok but if i rapidly open the throttle it bogs down on top end but if i let the throttle of a little bit and applie it slowly it seems to be ok
this problem posted appear's to be in the wrong cataogory but,
Check fuel filter/ fuel pump. I have seen both do that. usually the pumps die, But some have been known to have reduce performance so there isn't the fuel needed in fast demand but may provide adequate pressure when gradually applied
GL
hope this helps
Don
Aug 24, 2011 | Computers & Internet
Service engine soon light is on. Garage said they got a p0101 code. Engine idles OK but when throttle is applied engine starts to bog down and then the light starts to blink. If the throttle is reduced...
The code means there is a problem with the air mass sensor or circuit.
There are lots of possibilities, but the most common is that oil/water vapor foam from the PCV coats the air mass sensor and makes it inoperative. I suggest removing the sensor, cleaning it, and trying it again.
You can check it more accurately with an ohmmeter, but I don't know the normal reading range, and it should vary with air volume anyway.
But you can make sure it is not 0 or infinite ohms anyway.
Symptom is what you would expect, that the engine does not know you have applied throttle, and is still only giving idle amount of gas.
Perhaps a place like Autozone will check the air mass sensor if you bring it in.
If that is not it, then it is probably the control unit, with can also be brought in and tested.
Mar 11, 2011 | Chevrolet Tahoe Cars & Trucks
Bogging down when under medium throttle
Have you had the Catalytic converter checked? it could be due for replacement as they break down and cause tremendous back pressure.
Hope this Fixya's problem!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 16, 2009 | 2001 Chevrolet Cavalier
Can you fix my motor?
Fuel filter, air filter, basic maintenance such as tune-up (plugs and wires), cleaning the throttle body of the throttle sticks. Is the Check Engine light on?
How often is the oil changed? Does the exhaust smoke? I have a 1998 monte w/3.1l and just recently did all the above and a lower intake reseal to it...runs like a champ at 119k.
Also, these engines do have rev limiters on them..I do believe they're disabled when the brake pedal is depressed (applied). How many miles on the motor? Any more descriptions of the situation would be quite useful at this point.
Nov 11, 2008 | 1998 Chevrolet Monte Carlo
Ryobi Backpack Blower 25.4cc Logo
130 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
