Question about Honda Garden
I have a XR 2600 Honda pressure washer. After using it for about an hour, the pressure dropped drastically. I turned it off. I started the following day to finish the job and the pressure was a steady "stream" coming out of the wand - no pressure to clean the concrete. Can you tell me what might be wrong?
  • Honda Master
  • 7,733 Answers
Change the spark plug.
Posted on Oct 13, 2010
Honda blackmax 2600pressure washer will not start
Is the gas tank topped off? Is the water hose plugged into it and turned on? Is the gas valve open instead of closed? is the throttle turned on fully? Is the spark plug wire attached all the way? Should work after all of this.
Jul 12, 2014 | Honda Black Max 2600 PSI Pressure Washer
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.
If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.
http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Oct 08, 2012 | Honda Maxus Pressure Washer MX5222
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
Garden Logo
276 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
