I read your previous problem. This appears to be separate problems. The first was likely a loose wire. When a wire has a loose connection they build heat and can melt. The current issue would seem like the float switch is stuck. The float switch is a small white lever located on the right side near the water inlet valve. If you remove the toe kick you should be able to wiggle the float lever. They tend to get hung up after sitting for a while. Here is a link of a different model but same operation.
