Question about GE Dryers
I have a GE dryer and why does it stay hot if i have it on for a min. the number on my dryer is DWXR463EG2WW....
  • GE Master
  • 8,220 Answers
One of you elements might be broken and grounded to the panI have a GE dryer - 1ab9ae4.jpg
The only way to see is to get into the dryer and check it. I have directions HERE
Posted on Oct 13, 2010
GE dryer very hot on top--hasn't been used
Often times the element has broken (burned out) and is now touching the element housing causing it to heat up and stay on even though the dryer is not even running.
Mar 10, 2014 | GE Dryers
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Ge dryer way too hot. I have cleaned all the lint out but still way too hot. unplugged vent hose and ran machine still too hot. Took apart machine and tested continuity of heating element and its fine....
I do not know your definition of "way too hot". Remove the exhaust vent and insert a accurate thermometer in the dryer exhaust. Run the dryer on high heat. The temperature should get up to 165 degrees then cool down to about 125 degrees then back up to 165.
If it goes above 165 and stays there replace the high limit thermostat.
If it cycles correctly it is OK.
Aug 31, 2011 | GE DWSR405EBWW Electric Dryer
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Ge dryer staying hot even when it's off
This could be a stuck main timer control or thermostat. I recommend you un-plug the dryer until the problem is located. You don't want to start a fire or do more damage.
Mar 28, 2009 | GE DRSR483ED Electric Dryer
After starting,it runs for a couple of mins.,then shuts off,
it's over-heating sounds like you have a bad thermal switch
Jan 25, 2009 | GE DBXR463EBWW Electric Dryer
Dryer won't stay hot....
change your coils at the burner.
check the vent for blockage.
Nov 17, 2008 | GE DBXR463GB Gas Dryer
Dryer will not stay on
thanks for the question. how long does the dryer run for 1 min 10 min 15 min if it runs for 10 min or more you could just have lint covering the motor so it cant breath vacuum the dryer clean the venting this could cause this problem thanks the appliance doc
Sep 15, 2008 | GE Dryers
Dryers Logo
47 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
