Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
Need a password for factory reset
I am trying to do a factory reset on my spa2102-R. I dialed 73738# and was asked for a password. I tried "7UprUtew" (found from google) but it doesn't work.
Is there any universal password for factory reset?
Thanks a lot!
I want usename and password to access the IP Adress to the web
Posted on Sep 21, 2008
    Sergeant:
  • 287 Answers
You are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
Posted on Jul 05, 2008
Forgot mypattern to unlock phone its a concord zte768 I think can u help me
Try these steps:
ZTE Origin hard reset Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off.
2. Hold down Volume up key and press Power key at same time until the screen lights up.
3. Press Home Key to access Android System Recovery screen.
4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu.
5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset. ZTE Origin V768 Phone Password A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Jun 05, 2014 | Cell Phones
How do i set the linksys spa2102-r back to factory settings
Unplug the unit. Using a ball point point push down the reset button. While pushing the button down, power up the unit. Continue to hold the button down for 15 seconds or until you get a visual indication on the front panel.
Apr 23, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Password recovery on PAP2
There is a hard reset that can be done via the phone IVR. Connect an analog phone to the RJ-11 port on the PAP2 and pick up the handset, where you will hear dialtone. Press * (4) times and you will be told you are entering the configuration menu. Press 7 3 7 3 8 + # and you will be asked to enter 1 to confirm. Congratulations, you factory-defaulted your PAP2, the adapter will restart and you can log in with the default user name 'admin' with no password.
Mar 06, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I need to hard rest my Linksys Spa 2102 and it is asking me for a password. How can I get arrond this. The password was set by my previous Viop provider.
dial **** and 73738# and press 1 to confirm the resetting. wait for 1 minute
Whats the provider, sometimes they are provide locked :(
Feb 19, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys spa2102 i forget the password
Okay here is what you need to do.
try username : user
password : 1234
or
dial ****73738#
if it asks for a password use 8995523# or 7756112# or 5465866# or 50274537# or 78196365# (one of these numbers should work for you)
Hang up.
to check your linksys pap2 IP:
Pick up the phone dial ****110# The voice will tell you the current IP address. Write it down. Now you put that IP address in your browser and you should be able to get into your box type
http://192.168.1.103(for example)/admin/advance
Press enter.
Feb 04, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
LINKSYS SPA-2102 CAN NOT FACTORY RESET, PASSWORD REQUIRED!!
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband reports.com and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
Jun 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
We have power but no internet or phone lights are coming on.
do you get dial tone if you lift phone handset?
If so, Do you hear the voice menu after pressing ****?
If not, please unplug the Ethernet cable, and press **** again, then check if you now hear the voice menu?
Just in case you are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
Jul 05, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Password recovery on SPA2102
You may try to set to factory default. from the phone you can perform Factory Reset, Press 73738 then Press 1 to confirm.
Press * (star) to cancel.
If necessary, enter the password. The Phone
Adapter will request confirmation; enter 1 to
confirm. You will hear, “Option successful.”
Hang up the phone. The Phone Adapter will
reboot, and all settings will be reset to their
If you need further assistance please post your question
You idiot, the problem is, he doesn't have the password, how is he going to do that without it? If you're going to offer advise in here, make sure to read the entire problem first before blurting out stupid or ignorant sh*t that has nothing to do with the problem itself.
Feb 06, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
LinkSys SPA 2102
try this out
power on your linksys
then pick up the phone connected to that linksys
no dile tone required
dial ****
when it says configuration menu
type 73738#
if ask for password then nothing can help you buddy
and if it says press 1 to save then press 1 and your device is reset with factory default
Feb 05, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Password of linksys spa 2102
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
Nov 09, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
1,287 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
