Question about Kenmore 22422 Top Load Washer
My Kenmore 800 series washer is leaking water all over the floor and i can't find where its coming from. It only leaks when its on and running. I tried to take the back of it off to see where it was coming from but i could get it off. The washer is only 2 yrs old i can't believe that I'm even having this problem. I had a Kenmore washer before it was 12yrs old and i owned it for 6yrs. Is there any way there's a recall on this series or how do I fix it.
    President:
  • 1,430 Answers
Some of theses models have a tendency of leaking out the side of the pump housing. In this case you will need to replace it. Here is a link to help disassemble and acess the pump.
Disassembling a whirlpool style washer
Posted on Oct 13, 2010
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
I have a kenmore 90 series top loading washer and every time I wash clothes there is water all over the floor.
Disassemble and look for problems, there are several smaller hoses that can come off and allow leaks.
Sep 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Jan 26, 2009 | Dishwashers
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Heavy Duty 70 Series Model 110 water leak
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Mar 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,140 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
