Have a Niko OTP-2011r 20-in LCD TV (owned for 4+ years); TV works fine but remote is non-functional. Tried 2 different types of universal remotes and cannot get a code that allows us to do anything except scroll thru the channels (won't allow you to input a channel no. and go to it, for example). Other than scrolling through channels one by one and turning the power off/on, none of the other features that used to work, work. Any solutions here ... ? Any clue what code(s) might work on a universal remote? Or -- is there a particular BRAND/MODEL of universal remote that we could get that will actually work ... ?
  • 4,102 Answers
Hi you know the control that dont work do you still have it??
if you do have you checked the terminals have got no corrosion on them as it only takes a small amount of corrosion to cause loss of connection.
so check that 1st
if you still have the remote have you tried taking it apart and giving the pads behind the buttons a good clean and also the contacts the pads touch on the circuit board, usually the problem is something being spilled on it as it only needs a few drops of tea or pop to cause a pad to stick and this will prevent the control from working.
have a look at the control remove the battery cover and look for hidden screws inside battery compartment and under any stickers then remove these screws, then the chances are the top and bottom case is clipped together with little plastic clips so run a flat bladed screw driver along the edges until you hear it come free of the clips.
one you have split the case in half take the part with the rubber buttons on it it will be a big rubber pad with all the buttons attatched to it well take this out and put it in some warm soapy water and leave it to soak for few minutes whilst you look at the circuit board.
now with the board check the battery contacts are connected properly and that their are no wires worked loose to the batterys.
then look at the circuit board where the button pads press when you press a button you should see loads of round circuit type things, now give these a good wipe with a damp lint free cloth such as flanel, make sure its damp and not dripping wet so run it under hot tap then wring all the water out so its damp then give the circuit board a good wipe where the pads are rub quite hard to remove any stains or sticky stuff after you have done this let it all dry and have a close leek at it and check for any corrosion on any of the pads, if you see any corrosion get a match and use the wood end to rub away any corrosion and clean the contacts with this match or even broken tooth pick the wooden type, then when its fully clean leave it to one side.
now go to the pads in the soapy water now whilst it still in the water get a washing up sponge and give both sides a good clean front and back, dont press to hard on the back where the contacts are the touch the circuit board try and give each pad a clean on its own to ensure its fully clean and got no corrosion or sticky stuff from tea or pop stuck on it.
then take it out the soapy water and run it under the cold tap until all the soap is off run it under on both sides so its perfectly clean.
then get some kitchen roll and get it as dry as you can shake all the water off and get into all the little bits to get all the water out. now leave it to dry for at least an hour then check to make sure its perfectly dry.
once its dry put the control back together and put some new batterys in making sure their in the correct way, then give it a try and you should find you will have a fully working remote.
now if i have wrote all that and you tell me you no longer have the remote theni should have waited for your reply,
anyway with these all for one remotes they are pretty useless all they can really do is change the channels 1 through 9 and usually the channel up and down works and also the sound works but other than that all the other features usually wont work anything unless your very lucky and you keep doing the auto scan until you found the one that controls your telly properly.
when you do the auto scan dont save the first code that works the telly keep scanning and try saving the second code when it usually switches the telly into standby.
also when your doing the auto scan feature once its turned the telly onto standby try pressing the other buttons on the remote such as the number to bring the telly back on then try the vol button and any other button you need to use, it will allow you to press the other buttons as long as you dont press the button to save the code or press the standby button again
let me know how you get on or if you need further assistance ok
Posted on Oct 13, 2010
I need a power cord and a remote with a sleep button.
What?..... It doesn't work that way. You can get a energy saving power surge strip that would have a feature like this. But that is all you can do for this device
Oct 21, 2013 | Niko OTP-2011R 20 in. LCD EDTV
Problem:Won't turn on and off with remote or manually.
Mostly likely, it is your power supply. Is it getting hot? Most of them have a thermal protection circuit which will shut them off when they get too hot. You can order a new one off Ebay for about $20 -$40 depending on what voltage and current you need.
http://stores.ebay.com/LCDPAYLESS
Make sure you order the correct plug size too for your TV.
Apr 11, 2009 | Niko OTP-2613W 26 in. LCD Television
NEEDED remote and manual for my Niko OTP-2011R 20 in
Wow, not much support from Niko.
Their website is:
http://www.viewtekcorp.com/ (currently does not load)
Contact Info:
Viewtek Corp.
20957 E. Currier RD, Unit# G
Walnut, CA 91789
Tel: 909-598-6608
Fax: 909-598-6008
E-mail: service@viewtekcorp.com
I would try the company for the replacements and would obviously suggest calling the company (8:30am-5:30pm Pacific Standard) Monday-Friday.
Apr 02, 2009 | Niko OTP-2011R 20 in. LCD EDTV
How to set up tv from menu selections...
When on menu push the up down arrows on the remote to select what options you want.
Jan 18, 2009 | Niko OTP-2011R 20 in. LCD EDTV
Niko OTP-3211W 32' Mainboard Needed
We don't do email on Fixya and no idea who Jerry is. Keep all replies in the same post by clicking COMMENT under the name of the person you are replying to. Fixya gets 7 million questions a year, so the likelyhood of 'Jerry' seeing are impossible.
Here are your mainboards, 50 bucks.
Niko OTP-3211W TV Parts - ShopJimmy
www.shopjimmy.com/niko/otp-3211w
Niko 21VT3MB0224 (DA0VT3MB6F2) Main Board for OTP-3211W. $46.95. Part number is found on sticker. Set In-Stock Alert · Niko 24VV3EB0003 (DA0VV3TH2B2) PC Board. Out of Stock. Black Friday Deal. Cyber Monday Deal ...
Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W
www.shopjimmy.com/niko-21vt3mb0127-main-board.htm This Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W (21VT3MB0127) works for these TV models: Niko OTP-3211W.
NIKO 21VT3MB0224 Main Board for Otp-3211w ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components Find great deals for NIKO 21VT3MB0224 Main Board for Otp-3211w. Shop with confidence on eBay!
Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ...
www.ebay.com/itm/Niko...OTP-3211W...Main-Board-MotherBoard...-/28218366183... US$49.99 - ‎In stock
This main board was pulled from a working TV with a broken screen, please refer to the pictures. The last 2 pictures are of the TV this was removed from. This sale is for the Main Board and cables shown. I only accept Paypal. Paypal payment must be made within 2 days of end of sale. I will ship within 3 business days of ...
NIKO MAIN BOARD 21VT3MB0224 REV:F FOR MODEL OTP-3211W ...
www.ebay.com/itm/NIKO-MAIN-BOARD...REV-F...OTP-3211W-/172511137409 US$39.95 - ‎In stock
WE TEST ALL OUR PARTS AND GUARANTEE THEM NOT TO BE DOA (DEAD ON ARRIVAL). IF YOU EXPERIENCE A PROBLEM WITH THE PART YOU RECEIVED PLEASE CONTACT US WITHIN THREE (3) DAYS OF RECEIPT AND WE WILL WORK WITH YOU TO CORRECT THE PROBLEM EITHER BY EXCHANGE ...
Amazon.com : Niko - Niko OTP-3211W Audio Board DA0VV3AB2C9 ...
https://www.amazon.com/Niko-OTP-3211W-Audio.../dp/B00SVM5OR8 TV Brand: Niko TV Model: OTP-3211W Part Type: MAIN BOARD Board Numbers: DA0VV3AB2C9, 23VV3AB0004 Part Number: 23VV3AB0004 Specifications: Look for 23VV3AB0004 in your part to verify part number and compatibility. Other Specifications: Part number can be found on the sticker. This board has been ...
Main Board Otp ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-main-board-otp__samsung_power.html
6 days ago - Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit. $45.99. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. Niko 32" OTP-3211W. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. $49.99. NIKO MAIN BOARD 21VT3MB0224 REV:F FOR ...
Otp Niko Main ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-otp-niko-main__samsung_power.html
6 days ago - Up to 90% off brand name Tv Part only from your leader in online shopping including discounts on niko, niko main, board niko main, niko main otp, board otp ... Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ... Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit.
Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224
www.myshoptvs.com/.../7058-niko-otp-3211w-main-board-da0vt3mb6e4-m9204.ht... Find the best TV part Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224 at the lowest price online.
22VV3IB0018 Niko TV Module, signal, DAVV3PI12C4, OTP-3211W
www.tvpartstoday.com/22VV3IB0018-Niko-TV-Module...board.../22vv3ib0018.htm Part Number: 22VV3IB0018. Board Numbers: DAVV3PI12C4. TV Models: OTP-3211W. Type: Signal board. ... 22VV3IB0018 Niko TV Module, signal board, DAVV3PI12C4, OTP-3211W Email A Friend ... MODEL NUMBERS: OTP-3211W PART TYPE: Main Board TV TYPE AND SIZE: LCD, 32" MFR PART NUMBER: Niko ...
Niko OTP 3211W main board Google Search
Dec 30, 2017 | Niko OTP-3211W 32 in. LCD Television
Remote control codes
That is what I'm talking about, not even Niko knows of a code. That is why I had to buy a learning remote like the Sony RM-AX1400.
Apr 06, 2008 | Niko OTP-3211W 32 in. LCD Television
Need Power Supply
usually Lcd tv rated 12volts 3 ampers
but be careful.. check the polarity of ur lcd before plugging it.... some power supply has different polarity. good luck..
Feb 12, 2008 | Niko OTP-2011R 20 in. LCD EDTV
Need set up code for universal Comcast controller
I had to buy the Sony Rm-AX1400 and it learned the codes from the old remote. I found it at Bestbuy for 20 bucks. Look on ebay for one.
Mike
Jan 05, 2008 | Niko OTP-3211W 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
