Question about Canon CanoScan 5000F Flatbed Scanner
Preview and scanning image has colored lines mostly obscuring the image. Have uninstalled it all and re installed it many times problem is still there
  • 1 more comment
  • abeenbee Oct 13, 2010
    trying to send image of scanner screen with coloured lines obscuring card in background
  • abeenbee Oct 16, 2010
    THANKS VERY MUCH FOR HELP AND ADVICE. HAVE DECIDED TO REPLACE AS UNIT IS WELL OUT OF WARRANTY, THE INSIDE SEEMS INACCESIBLE AND IT APPEARS CLEAN AND CLEAR BUT REMAINS FAULTY. MANY THANKS AGAIN
  • abeenbee Oct 17, 2010
    THANKS FOR HELP AND ADVICE. HAVE DECDED TO REPLACE UNIT AS ALL APPEARS CLEAN AND IN ORDER AND INSIDE SEEMS INACCESSIBLE THANKS FOR YOUR TIME AND ATTENTION A.K.B.
  • Canon Master
  • 4,737 Answers
If reinstalling the Program/driver didn't help, it's most likely that there's something physically blocking the Scanner Lamp or something on the Scanning Glass or possibly problem with the scanner lamp flex cable. From you end, you can try cleaning the Glass and the Lamp after disassembling the Machine. If this doesn't helpful, your only solution is Canon Support, they will send their engineer and will check the machine and will replace the necessary components, if replacing isn't helpful, they will replace the unit (if it's still under warranty).
If you can upload the scanned image, that will be very helpful for me to help you troubleshoot.
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
Posted on Oct 13, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 17, 2010
    I am so sorry, I should get back to you earlier with though it might not be possible. Actually I didn't receive the notification, the only one I receive is this one [not the comment, but the alert that problem is solved]. I hope you'll forgive me.
    Anyway, I once again wish you good luck.
The colored lines are due to certain CCD cells not responding properly. The problem can be due to dust inside the scanner or on the CCD or mirrors blocking the light from reaching the CCD. This problem is also caused by defective electronics in the scanner
Posted on Oct 14, 2010
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
Could you help me to operate the scanner., so that I can send docs,
make sure your scanner is working properly and the software has been already installed to the server or computer to access the scanner. this steps can help you to operate the scanner.1. connect the scanner to your PC, mostly scanner now is using USB cable 2. and then turn ON your scanner, place your material to be scanned like you were using photo copier 3.press the scan button to acquire the image 4. then preview the scan, the scanner software should display a preview on your computer screen 5. and now select the scan area in the scanner software 6.next set other options for example set the the color or the resolution of the document 7. then scan the image and save it into your disk make as your new folder. after you save you can now send this document.
Apr 15, 2011 | Office Equipment & Supplies
Canon 8400F scanner refuses to scan 12 negatives at a time. Preview shows them all, but the "select all frames" is grayed out, and refuses to function. I can scan manually one negative at a time among...
Check to see if the "Thumbnail Display" is on or off (first icon on the toolbar in the ScanGear CS window). If it is on, a colored border will appear around one of the images in the preview display, but you will not be able to select all frames. If you click on the Thumbnail Display icon to turn it off, only a dotted line will appear around one of the images, but you will be able to click on the "select all frames" Apply button.
Dec 09, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection V100 Photo flatbed scanner
I would not think Norton is the problem but one can never be sure - Uninstall Norton to prove one way or the other Then come back
Aug 25, 2007 | Epson Perfection V100 Flatbed Scanner
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner Logo
314 people viewed this question
old marine
old marine
