Question about Kenmore Refrigerators
I just moved into this house last month and I noticed the refridgerator seemed to be running all the time and/or making noises in the back. yesterday I noticed that the top (fridge) wasn't staying cold but the freezer was. Help!!!!! Katrina
  • 49 Answers
Check to see if the underside is free of lint or dust. It may have gotten something blocking the condensor fan under the back side.
You may have to remove a paper panel off the back to see it.
With all that done, you may have an evaporator motor bad or hitting something. It normally blows cold air into the fridge compartment.
Posted on Oct 13, 2010
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
I got this .bn20513ww not a month ago and notice it make loud knocking noise
Hello, Thank You for using FixYa. I will be helping you today.Does it only make the noise when the compressor fist comes on for a minute or so? If so its the freon lines in the walls flexing from temperature change and moving in the walls it wont damage anything but it seems to be an issue just because it is annoying ,more so at night when the house is quiet.This is all i can thing of unless its the icemaker,If your water line is not hooked up and your icemaker is turned on it will be making noise from running dry.If so just turn the icemaker off.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
My '98 Taurus started making a clicking noise yesterday and seems to be running hot, the noise continues even when in park and increases with RPMs. I'm guessing that it might be the water pump, I don't see...
most likely you're right on it bad water pump, some times they don't always leak when bad. you can take radiator cap off while running to look @ see if it's circulating though thats a start
Aug 15, 2010 | 1998 Ford Taurus
Service traction system light on after getting new tire
wheel bearing about to go bad.. Notice any slight roaring noise??
Mar 17, 2009 | 2003 Oldsmobile Silhouette
2002 Kia Rio Cinco Noise in Engine Compartment Getting Worse
if you wanna change on your own it be cheap probably in the middle of 17 and 26 for timing belt so do not worry about expenses they need to change every 60k miles thats two thumbs up..also you might check your drive belt they tend to make noise when its worn or bearing on your alternator or power steering also you need to check power steering fluid if there low they tend to makes a grinding noise too..
Jan 10, 2009 | 2003 Kia Rio
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
The coil was frozen on my unit as well. Guinco tech Ron announced that this was a bad system board. Seems to be resolving as of this writing.
Jan 02, 2008 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
