Question about Magic Chef MCWC16MCG Wine Cooler
The compressor overload keeps poping when i plug the unit in.
I would suggest you plug it into a power bar with surge protector to see if that solves the problem.
Posted on Oct 13, 2010
My a/c unit keeps tripping when i plug it in. i've tried to hit the reset button on the plug but doesnt do anything. i unplug and plug back into outlet and it trips again. what can i do to fix it?
There is nothing you can do to fix it... the compressor is trying to start and cannot so it trips the plug. The plug trips to protect the house circuit from being overloaded and causing a fire.
Getting the compressor replaced is cost prohibitive, it is cheaper to buy a new unit.
heatman101
Aug 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
My fridge is clicking at the control panel, and it quit cooling and freezing.
Most likely your PTC start relay on the compressor has failed
It is item 733 of this diagram: PN: WR07X10052
http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSS25GFPAWW/1811/0165000/H3090204/00008?blt=06&prst=0&shdMod=HSS25GFPAWW
When a PTC relay fails I most always change the overload and the capacitor also. The reason for the overload change is that as of this moment it is still cycling and they do age and stop performing properly. The capacitor.. just so you have a known good one.
The capacitor is item 729 above link.
The thermal overload is item 735 above link.
You may get by without changing item 735 (the overload..) but if it does not cycle in 40 - 45 seconds after a brief power loss it should be changed. You can test it by unplugging the unit for 45 seconds and then plugging it back in. The system has not stabilized so the compressor will NOT start, yet the thermal overload will cycle every 4 minutes or so depending on temps. Once the thermal overload is cycling you must unplug the unit for 15 minutes to allow for coolant system pressures to stabilize and compressor temp to drop.
Before you order parts... try un-plugging the unit for 30 minutes and then plug it back in. It may start.
If not.. we do a continuity check of the 3 compressor terminals individually to the case of the compressor. (NO SHORTS or grounds are allowed!) If there are shorts.. the compressor is bad. The next step (no shorts) for sure is the PTC relay and capacitor change. If it still cycles at this point you must change the thermal overload. If at this point it still does not operate normally most likely the compressor rotor is locked. (compressor change)
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | Hotpoint HSS25GFP Side by Side...
MY FRIDGE STOP WORKING AND THE COMPERSSOR IS VERY HOT. What can be wrong with it it is only 2 years old
Usually when a compresso that is not that old gets hot the problem is with one of 3 components
1. The PTC Relay PN P6R8MC
http://www.repairclinic.com/SSPartDetail.aspx?s=t-P6R8MC-%3d%3di1206838&PartID=1206838
2. Thermal overload PN 265RFBYY
one of many sources: http://www.repairclinic.com/SSPartDetail.aspx?s=t-265RFBYY-%3d%3di1206539&PartID=1206539
3. Loose wiring or terminals
4. Worst case the compressor itself (5 Year carry in warranty!)
Items 1 and 2 above should be changed at the same time. Usually when one fails it causes the 2nd one to fail.
Before you go ordering parts.. just unplug the unit for about 45 minutes. Sometimes if there is a brief power outtage (less than 3 mins) the unit stops and the coolant has not equalized. The compressor keeps trying to start keeping the pressure up but yet the compressor does not start normally. The compressor gets hot and the thermal overload causes the unit to cycle on about every 5 minutes. Over an extended time of cycling the thermal overload will fail. After 45 minutes plug the unit in and see if it starts
If you change the PTC Relay you must change the KliXon thermal overload at the same time. Most LOCAL Appliance part supply stores will have both of these parts in stock. Use the part numbers above and walk in with the parts in hand.
IF you decide to change them your self FIRST make yourself a simple wiring diagram
I.e Orange to terminal ___
Blue to terminal ____
Then remove the parts by opening the plastic cover on the side of the compressor and then pull off the PTC and Thermal overload HORIZONTALLY. Obtain the replacement parts and reintall after inspecting the compressor terminals. Clean as necessary by scraping with a knife blade.
If after changing these two parts the compressor still does not start you may very well have a warranty carry in service compressor change. I seriously doubt that the compressor has failed but it does rarely happen.
This is the Magic Chef support website for parts (linked page) and warranty (top of linked page)
http://www.mcappliance.com/partorder.aspx
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Magic Chef MCBR360S Stainless Steel...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
It keeps popping the breaker, and i don't have manual to find out why
Either you are connected to a breaker that has a large load on it before you plug in the compressor and adding this unit simply is overloading the breaker or you have a wiring issue with the compressor.
First try plugging it into circuit that has no other draws on it - that will answer your first question
Mar 05, 2010 | Craftsman Air Tools & Compressors
Compressor comes on occasionally wont run long enough to cool down..
your rtc overload on the compressor is getting weak and drops out and this shuts power off to unit and you need to replace it,its plugged into the side of the compressor located in the lower rear of the unit,simply unplug frige,access the compressor,remove retainer spring,unplug rtc overload and replace it
Jan 08, 2010 | Kenmore Refrigerators
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
HNSE05SS Compact Frig
There are very few parts on this unit. UNPLUG unit jump out the 2 wires to the t-stat. plug it in, if it runs the t-stat is bad.
After that theres the overload /start component on the side of the compressor. UNPLUG remove cover look for burnt wires , wires are ok feel if the compressor is HOT to the touch. if it is it could be off on internal overload. let it sit for a while plug in and listen for a hum or click in the compressor. If there is a Hum then click your back to eather your overload /starter is bad of the Compressor is bad. If you have an amp meter you can check the compressor by clipping the meter on power wire. on the information tag that has the model and serial # there is a amp draw for Lock rotor. If the unit draws Lock Rotor amps the compressor is bad.
May 21, 2008 | Haier HSB03 Compact Refrigerator
Electrical unit attached to compressor keeps making a spark(clicking sound) Fridge & freezer slowly stopped cooling during the day and is now down to 0 cool.
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
May 03, 2008 | Refrigerators
Magic Chef MCWC16MCG Wine Cooler Logo
218 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
