Bosch WFB2004 Washing Machine with Very Hot Water Washing
No matter which setting I use, the machine washes at a very high water temperature (so I have some rather small clothes now!)
I think the thermostatic is faulty, is this easy to fix if this is the problem?
Many thanks
  • 1,314 Answers
Check to see if the hoses are on the wrong valves like hot connected to the cold valve
Posted on Jun 02, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My bosch washing machine has taken to only allowing washing at 30 degrees. When a higher temperature is requested, no water flows into the machine. Any ideas why?
Clogged/defective/burnt out hot water valve. Disconnect hot water hose and clean the filter in the valve inlet. If this did not help, check if there is power to the hot water valve when it's supposed to fill. If there is power, but no water is coming into the washer - replace the valve.
Apr 10, 2010 | Washing Machines
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
May 13, 2009 | Bosch Washing Machines
No hot water after move for washing machine
Check to make sure the hot and cold water tap is turned on at the back of the washing machine, if there both on and working the water inlet valve could be defective.
Apr 08, 2009 | Bosch Washing Machines
Bosch washing machine
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Jan 19, 2008 | Washing Machines
Only hot water pipe going in
Don't know that particular make, but if there's only one water inlet available the machine should use its own electric heater. A "Wash Temp" setting switch should be available.
Jan 14, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Water Temperature
you have the water tubes connected wrong way round ie cold to hot and hot to cold - honest. change them over and bet its cured
Apr 20, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
