Question about Whirlpool Dryers
Everythings running but without heat - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 13, 2010
2005 gmc safari heat oneday next day no heat
This could be a few things that could cause this problem...Do you always hear the blower motor run with or without heat..?..knowing this would help me answer your question...It could be the heat blend door inside Your HVAC system behind dash ..These doors can stick or break..The best thing you can do other than trying to troubleshoot everything ,guessing and getting a headache is take it to a dealer and let them scan the system...They can find the problem with or without a trouble code...It may cost $ 100,00 dollars to have it scanned however it will save you money in the long run...
Feb 25, 2015 | 2005 GMC Safari
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
1996 CADILAC OVER HEATING
do you have a northstar engine ??? my 97 did that too found bag smell in coolant tank turned out to be water running out tail pipe ,from head gasket , i hate giving bad news , but check everything water pump is a problem as well as drive belt slipping ,thermistate stuck ? do not try running without thermistate that will cause to overheat faster.make sure all air is purged out of cooling system , i hope something here is helpfull,good luck.get back to me and i'l see if there is any thing more ,
Oct 01, 2012 | Cars & Trucks
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
First the motor cooling fan quit working and then it was running without the cooling fan working and everything shut off. It is as if it is unplugged.
The cooling fan protects the magnetron from overheating when it is running, the magnetron has probably been damaged and has shorted due to the excessive heat that they generate and blown the main fuse in the microwave to stop any further damage. The repairs for parts and labor will not be justified and replacement in the long run will be cheaper.
Jan 24, 2011 | Frigidaire FMV156DC Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
FAN SHUTS OFF BUT COMPRESSOR KEEPS RUNNING - 6 MONTHS OLD
Depending upon the model of your air conditioner, this may be normal operation.
My newer Dometic air conditioner will run the compressor in a "reverse" mode without the fan occasionally in order to heat the coils. This is done to defrost the coils. After the frost is gone, the fan switches back on and everything goes back to normal.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Defrost Cycle Problems
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
