Question about Vacuums
My Braun tootbrush has never charges-i have a 240 & 11v shaver socket but nothing seems to happen when i plug it in?
  • 171 Answers
When charging a device on some type of charging block you need to plug it into a regular 110 socket as the block has the correct modifications in it for the device that it charges. This 11volt shaver socket is for older shavers that dont charge up you just plug them in and use them.I hope this helps you ....good luck
Posted on Oct 13, 2010
Dyson upright vacuum with kinked cord kept stopping. There was a loud bang and smoke and the vacuum stopped. Has the motor blown up, or can it be repaired?
This happens a lot the supply cable bending or damaged shorts out causing smoke and a bang if fitted with or backed up with a high amperage fuse .
check length of supply cable if you find damage/ burning smell,
either replace cable, or you could fit a inline rubber socket and plug by cutting out damaged part of cable and fitting female part of plug first into supply cable 1. then on the vacuum side of cable fit the male part of plug 2 . supply 1. -----o o----------2.--- vac
using insulation tape if you like you can tape plug and socket together to stop it pulling apart, normally cable damage will not damage the vacuum cleaner. and fit the correct fuse rating for the machine 1000 watts at 240v divide 240 into 1000 =4.166 amps
so with a 1000 w load you do not need a 13 a fuse fitted 6 amp fuse should be ok. or go online and see what is recommended re fuse size for appliance ,
Nov 12, 2016 | Dyson Vacuums
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Jul 24, 2014 | Karcher WV50 Window Vacuum
Nothing happens
it could be the wiring coming from the vacuum itself you might have to change it.can be brought at any electrical wire store have you checked the plug wiring is it all intact or has some came out from the terminals?
Apr 06, 2014 | Electrolux Z4735AZ Gazelle 1900W Upright...
BRAUN MANUL FOR A JUICER
If yu have the model number of your product you should be able to find your User Manual here:
http://www.service.braun.com/home.asp?rg=EU&c=GB&l=GB&typ=ui&s=&seite=&sString=
May 14, 2011 | Vacuums
How do you take apart the Braun 4700 series shaver. I need to replace the battery, so i need to access the inards. Thanks
In the back of the shaver are two screws, one on each side of the plug pins. You need a tiny flat-head screwdriver. Take these screws out and the entire outer shell of the shaver pulls out from just behind the head.. Now your next challenge is trying to find replacement batteries with the little tip on each end.
Dec 09, 2010 | Vacuums
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
My henry vac switch is dead.
You will need to remove the top cover of the vaccum by removing the 4 screws underneath.The you need to test with a multimeter if you have 240 volt power to the bottom of the switch. If you haven,t power there you will need to check the plug connection or replace the power lead.
Jan 08, 2010 | Henry Numatic "" Canister Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
