Question about LG Dishwashers
Hello - I have a LG LD 2060SH and wanted to clean it completely - sadly I have a part called the Valve or Float Component (small white plastic thing!!!) and I can't locate where it should go! Yes, I undid all the bottom filters on the water inlet system and spray arms, they were all clogged even after special cleaning - Can you explain where it goes as I put everything back together - now it is all squeaky clean! I knew I should have taken pictures along the way, but I was so happy that everything came apart so easily. I have an added gusto as I managed to change the door seal on my LG 2 weeks ago form this site, a nightmare job, but I did it, with a little help from my husband!
  • 49 Answers
There should be a little hole in the bottom of the DW and it simply slips back into that hole.
Posted on Oct 13, 2010
The motor is suddenly making a loud noise throughout the wash cycle - why would this be and how can I stop it??
Posted on Jul 17, 2011
I have no water coming into the dishwasher, i have cleaned the filter but it will not operate. The dishwaher is on but no water is coming into the unit
Hello there
If there's no water entering your dishwasher, check these: Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jan 26, 2011 | Dishwashers
Dishes on top rack not getting clean and detergent door is opening but detergent remains in cup
Hello. The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. It could also be the Float switch: The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Oct 02, 2010 | Dishwashers
Water will not pump into dishwasher but will pump out
Hello. there are two devices that control the flow of water into a dishwasher. They are the water-inlet valve and the float switch.
Nov 18, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
No water
check these:
Water-inlet valve
Float switch
Aug 16, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Ly dishwasher is getting less water
You need to check the following :-
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | LG Dishwashers
Tablet not dissolving, dishes not clean
Hi Trina. I wish I was nearby as I would come over and take care of this problem for you.
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
May 08, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
No water is entering the Exxcel auto option dishwasher
hello there,
2. Float switch
Water-inlet valve
Float switch
thanks for using FixYa
Jan 28, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
222 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
