I cant get any bass to come out! i have plugged in the additional sx-r275 speakers into any logical output but they never make any soudn. i dont ahve my remote. do i need that to turn on some sort of surround setting?
    Genius:
  • 1,126 Answers
Yes it does have to be in a different surround setting to work.
Posted on Oct 13, 2010
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
LEFT SPEAKER HAVE STATIC SOUND AND NOT CLEAR
Hi what are you listening to like cds or tape or radio also are you using copy cds
Apr 02, 2008 | Kenwood KR-X1000
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
I have a aiwa cx nhmt75 home theater system which the surround sound rear speakers I believe model # sx-r275 for them has been misplaced or destroyed could you tell me what speakers can be used in place of...
You should be able to use any decent pair of speakers with an impedance between 8 Ohms and 16 Ohms and maximum power capability of at least 33 Watts. The link provided is for the specifications page of the owner's manual.
http://audio.manualsonline.com/manuals/mfg/aiwa/cxnhmt75.html?p=31
Aug 28, 2017 | Audio Players & Recorders
Using satelite speakers on arcam avr100
Depending on the type of satelite speakers, Bose for example used on their own would be damaged, if your satelite plugs into a sub speaker they are protected by circuitry that controls output level when tied into the whole system, so using them on their own is not a good idea.
Mar 30, 2012 | Arcam AVR-100 Receiver
Is the bass boost the gain or frequency knob?
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
I have this radio soundstream vir 7000nr. i have a speaker and a amp in my trunk. the only problem is it only plays base. i currently have it plugged in under subwoofer. i dont know where else to plug it...
that deck has front, rear and subwoofer RCA outputs, plug it into front or rear.
additionally, check the amplifier in the trunk to verify that the "crossover" circuit is NOT enabled. if the amps crossover is set to "low pass" or:"LP", then only bass will come out, and if it set to "high pass" or "HP", only highs will come out. you want the crossover on the amp in the trunk set to "off" or "full-range".
Mar 09, 2011 | Soundstream Vir-7000nr Car Video Player
No sound device in macbook air
Apple menu (top left) System Preferences > Sound > Output tab select the Internal Speakers
check your output volume and make sure the Mute checkbox is unchecked.
Plugin a pair of headphones. If you still have no sound. The sound board needs to be replaced, which is attached to the logic board. Meaning the whole logic board needs to be replaced.
Jan 20, 2011 | Apple MacBook Air
Old Aiwa Speaker Assistance.
Considering you only have 3 speakers, I would think you would be further ahead by purchasing an entirely new system.
This article explains the differences between Dolby 5.1 and Dolby 7.1 surround sound:
Home Theater Receiver Guide 5 1 vs 7 1 Which is Better
In terms of brands, I'd recommend finding a complete set up that's in the price range that you would like to spend.
May 19, 2017 | Aiwa Audio Players & Recorders
 Grubhead
Grubhead
