Question about Maytag MSD2656G Side by Side Refrigerator
When my refrigerator defrozed it does not go back up. This would happen every 5 or 6 days. I have to turn in off and turn it back on for it to start working again.
  • 49 Answers
This probably has a solid state defrost timer. It will have to be replaced.
Posted on Oct 13, 2010
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
Mar 03, 2014 | GE GSH25JFR Side by Side Refrigerator
Why don't the defrozes don't work and heater
either your fuse or relay is tripped,concerning the fan. if no heat at all, ck operation of dash actuators, their vacuume coutrolled
Jan 02, 2014 | 1993 Chevrolet Caprice
Windows fogging up while driving. Run defroze, but side windows and outer edge of windsheild fog up. If you stop driving they clear after about 10-15 minutes of running defroze. If I put rear windows down...
to defog the glass , run the ac along with the heater
the ac takes the moisture out of the air in the car and the heater dries it out
close of the air inlet so that it recirculates inside the car
Jul 07, 2017 | 2006 Dodge Magnum
Beverage Air MT17 cools sporadically. I turn the temp control setting to 5 and it will go down to 28 degrees F and the next day it will be at 55 F. I have to turn the control knob to off position then turn...
Low refrigerant would make it inefficient but if it chills to 28° it can't be that bad. I think you have a control issue. The compressor runs when you reset to off & on, then chills until it satisfies the thermostat, then shuts off. But then is not starting again when the temperature rises. You'll need to follow the control wiring to see what contacts are open and not passing power to the compressor. Control wiring is typically 24v ac or 115v ac. There's also the possibility that the compressor is tripping out on overload at 28°. You effect a reset when you turn it off, then on.
Mar 26, 2017 | Beverage-Air MT17 Refrigerator Commercial
Where is the defroze timer located
Typically the defrost timer is located in the control panel where the refrigerator thermostat is
Jul 26, 2011 | Kenmore Side by Side Refrigerator
What would be the problem if refrigerator become a freezer.......all my vegetable and stuff that should stay cold become frozen ....I have a Kenmore elite top mount refrigerator which I bought 5 years...
this can happen when your ice can start to block vents ...try turning off your fridge for 2 days so any ice blocks that have formed can melt right down , then switch back on ....should do the trick
Oct 19, 2010 | Refrigerators
Motor running sound present. Autostop functioning. Cooling very less. vegitable perished
can you try to clean all the surroundings including the grill and the motor, and do a completely defroze then turn it on, and we'll see the result. ok
Mar 12, 2010 | Daewoo FR-064R Refrigerator With Ice Box
Freezer noise and defrosting
You need to contact a repair shop ASAP.
May 01, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Problems with Frigidaire FRT18HB5DW0 Top Freezer Refrigerator
may be your thermostat is easy to cut off or not functioning ,pls check the thermostat .
Regards,
Edgz
Jan 27, 2008 | Refrigerators
Maytag MSD2656G Side by Side Refrigerator Logo
42 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
