Question about LG RH1999H DVD Recorder/HDD Recorder
I have an LG hdd dvd recorder (RH398H-M) I also have Shaw Hd receiver but I can't get the HD channels onto the LG recorder ?????
  • 5 Answers
SOURCE: DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Posted on Feb 08, 2008
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
SOURCE: i have a lg dvd
If you read the instructions, it's under "Dubbing" - Page 51. The one thing the printed manual fails to tell you is that you need to "finalise" the disc if you want to play it on any other player apart from another RH7823W - DOH! See page 23.
Posted on Apr 20, 2008
  • 4 Answers
SOURCE: When I turn on LG
Your DVD loader (DVD player) has some kind of malfunction. (dirty lens, bad build, etc...)
Just stick a new PC IDE DVD player in it and it will start working. I had the same problem.
I used a lite on made in 2004 and the RH1888 works prefect, but does not look perfect. The drive is won't work in conjunction with a it's original face panel.
I blue tacked the display on the top of the chassis, and got the big ol' lite-on drive sticking out front, but it works perfectly.
Good Luck!
-Pro Hack
Posted on Oct 30, 2008
  • 909 Answers
SOURCE: how to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
Posted on May 29, 2009
When finish rec from HD to DVD it wont finalize it , Keep coming up Navigational Error , even when playing normal DVD
you can not record from HD to DVD because it has a lot of difference in resolution .....for HD you need blueray disc not dvd.....
Sep 28, 2015 | LG Rht599h 500Gb Hdd Dvd Recorder With...
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Backup hdd to external hd
DVD recorders are usually not the first selection for backup of data files. you may be better off with a 1 Tbyte external drive, which is suited for that purpose. Even though the DVD drive has the capacity, there are usually formatting issues with data files being burned to a DVD recorder.
May 19, 2012 | LG Computers & Internet
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have DR386D DVD Recorder and I cannt get it to tune in to HD Channels. The message I am getting is "HD Service not available" I am getting HD channels on my LG TV so I assume that the Antenna...
I wonder if this model is meant to receive HD channels in the first place. If it isn't, that is probably why you get that on-screen message. If it has a built in SD digital tuner, then it is not a HD digital tuner/DVD recorder; it would only be SD, hence the message.
It is possibly a limitation of the model, not a fault.
Mar 02, 2011 | LG Televison & Video
Hello, I have purchased an LG RH397D DVD Recorder in Brisbane Australia. Eveything works well except that I cannot receive channel 73 (mate) and 90 (Go). I can press guide and the recorder will tell me...
its simple ,HD stands for "high definition" and either your TV or DVD player cant do HD ,these channels will be only screened in HD ,this is why you cant watch them ,you will need to update one or both of them .THANKS for using FixYa
Feb 10, 2011 | LG Televison & Video
Cant record now i have a set top box
Press Av button next to HDD button 3 times. The first time selects the built in aerial connection, the second press selects a camcorder and the third time will give you access to a connected HD set top box with all its stations
Feb 15, 2010 | LG RH1777 DVD Recorder
HDD/DVD Model RH265 : worked perfectly for 14 months. Now will not allow deletion of data from HD and also will not allow recording to HD. Symbol circle with diagonal bar appears on screen . Still allows...
Sounds like the hard disk might be full. How many recordings have you got on the machine? You say it won't allow you to delete "data". Have you protected the recordings?
Jun 30, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Connect satellite receiver to dvd recordrer
there is really no way around it. Directv and Tivo are releasing a new receiver in a few months. Or you could purchase a HD dvr. Directv's receivers dont send any guide data thru a RF output, only picture and sound. The recorder you have is great for cable.
Jan 06, 2009 | Televison & Video
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
LG RH1999H DVD Recorder/HDD Recorder Logo
210 people viewed this question
Computer Repairing
Computer Repairing
