What is the specification for MXN13FB12R motor used in VCR loading mechanism of Panasonic VCR? I am interested in the operating voltage, no load speed and torque characteristics of the motor
bigg t
  • 640 Answers
SOURCE: Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Posted on Feb 22, 2008
  • 4234 Answers
SOURCE: Part for VCR mechanism
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
Posted on Oct 01, 2008
  • 1388 Answers
SOURCE: Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Posted on Nov 30, 2008
  • 54 Answers
SOURCE: I HAVE HITACH SCREW COMPRESSOR MODEL SDS-H31A MFG
You are best off contacting the motor manufacturer. They should be able to get that for you.
Posted on Dec 10, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: how can I get operation
The Panasonic site for Oceania says you can purchase a manual, but you can download the manual for the UK model from Panasonic here. It's probably similar enough that you can use it. Thanks for using Fixya!
Posted on Oct 17, 2010
Testimonial: "THANKS ! You're a legend !"
I have a Panasonic NV-VP60GL, it has repeatedly come up with error code f04. From what I've been advised this is to do with the loading motor. I replaced said motor and still get problem. Help please?
F04 actually just means the mechanism locks during unload. The load motor can indeed cause this, but it can be working fine, but the timing might be out. This could be something to do with the mechanical parts of the mechanism. You should examine it for broken or worn plastic parts.
Mar 19, 2015 | Panasonic Televison & Video
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Casette is stuck in my panasonic nv-hd 680 vcr and display shows F4.Could anyone tell me how to solv it -please !!
I believe F4 means the mechanism is locking up when unloading the tape. You should look into the operation of the loading motor.
Jan 01, 2013 | Panasonic NV-HD680 VCR
Tapes don't load
Perhaps some physical damge to either the main mechanism or loading/carriage mechanism if you can't get a tape inside the unit. The power shut off is an automatic response, when the operation becomes comprimised.
Jun 06, 2012 | Panasonic AG-DV2500 DV/Mini DV VCR
Have a samsung DVD-V1000 VCR/DVD combo unit. DVD player works fine. been experiencing gradual decline of the VCR and now it won't play at all. will **** tape into the machine but can't get it out. any...
Always frustrating when a videotape gets stuck in a failing/failed VCR deck. Since all decks use a loading motor and gear system, it would be a simple matter of gaining access to the terminal pins of the loading motor (assuming you can see these from the top of the deck) and applying 9V DC voltage to 'unwind' the loading mechanism - you may get a little bit of tape outside of the cassette, but at least it's ejected. If the DVD deck works as you say, you may be able to continue using this for a while.
If the loading assembly is toward the underside of the main deck, you may need to remove the entire VCR mechanism - then you can apply the 9V to the motor to unwind the gear (it is easier to apply a low voltage to the deck rather than use physical force to unwind gears - as you may damage them) - while leaving the DVD deck in the unit untouched. There should be 2 separate mechanisms in this combo - 1 being for DVD the other being for VCR - as long as you are careful when removing the VCR deck, you should have no problem retrieving your tape (with maybe a little creasing but otherwise undamaged) from it. Be careful when removing the top cover and front panel assembly; you don't want anything broken.
Since VCRs are becoming obsolete these days, it is hardly worth getting this one repaired by any service centre (unless you want to pay a fortune, which is usually more than the retail price of a new combo unit). It's up to you.
NOTE: you cannot operate this unit with the VCR deck disconnected from the motherboard (you will get an annoying error display with the VCR removed). Once you have successfully removed your tape from it, reconnect the VCR mechanism to the board - but do not use it - just use the DVD part if that is still OK. Refit the covers, plug machine into power. Done!
You need a lot of patience to undertake the abovementioned action. Fingers crossed.
Mar 28, 2011 | Samsung DVD-V1000 DVD Player/VCR
There is a DVD in the machine and when we push eject the tray doesn't open to eject the DVD.
Possible that the mechanism is struck and the loading mechanism can be out of alignment. It will be important to remove the loading mechanism after removing the covers ,check the motor drive,belt and the gears, check the voltage to the motor. If there is no voltage then the drive can be faulty, check the motor drive IC in the board.
Feb 19, 2011 | Sony RDR-VX515 DVD Recorder/VCR
When i insert a tape into Panasonic AG-DV2700 Mini dv Playerecorder. It closes normally and then it puts the tape back out staight away Thanks Maurice
Dear FixYa customer,
There can be several reasons for the tape spitting back out including, a defective tape, foreign object/lablel in the cassette compartment, unit in timer recording with tab knocked out on tape and then actual mechanical and electrical faults.
I will concentrate on the mechanical and electrical faults here, since you can verify the others.
Electrical, would include the Power supply, and Micro processor circuits.
A weakened power supply due to deterioration of the filter components will kick the tape out if the power supply voltage drops below a certain value. The filter components deteriorate with age and heat, and then put out less voltage.
There are critical timing circuits, and sensors that control the mechanism positioning and send signals to the Micro processor. The tape in sensor, mode switch, and LED are common faults here.
Mechanical faults include the Cassette Loading Assembly, Capstan, and Drum motor. A fault in the casseette housing assembly that won't allow it to load 100%, a Drum or Capstan motor that is sluggish or frozen will send a signal to he CPU to kick the tape back out.
The Power Supply is a common failure.
An experienced technician can verify the power supply voltages and replace the filter components for approximately $25.00 plus labor.
Thank you for using FixYa
May 13, 2010 | Panasonic AG-DV2700 Mini DV VCR
I have a panasonic NV-HD620 with a F04 error message.
You appear to have a K Mech model. F04 means the mechanism locks unloading. The cause of this is the Load Motor timing.
Sep 09, 2009 | Panasonic NV-HD680 VCR
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Stuck vhs tape
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.You will need to take the cover off. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping.
Hopefully, you won't find any spilled tape in the unit.
Also look for a broken spring or cracked gear or gear with missing teeth.
Let me know what you find out and we'll go from there.
Good Luck, Jim
Mar 02, 2008 | Panasonic PV-C2010 20 in. TV/VCR Combo
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
