Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe SUP 012
Our machine makes a lot of noise but no water ever comes out. We see water in the tray? Which part would we need to replace?
  • 487 Answers
Open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Posted on Jun 03, 2008
We have a saeco magic deluxe maker SUP 012 that has a cracked water reservoir. We would like to order a new one. Could you please advise us? Thanks
Howdy, they don't have a central online parts distributor, but rather several physical locations throughout the states. I was able to get their customer service number, though, which may be of the best use to you.
Saeco Customer Service at 1.800.933.7876
hope this helps:)
Farmerbear
Aug 31, 2010 | Saeco Magic De Luxe Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic type sup 012 problem
Hi sad_loser
Your problem is easier. On the top left side of the brew unit is a thumbscrew that holds the filter screen in the brew head. See if you push down on the thumbscrew you can get the filter screen to move? If it dose pull down on the filter screen and see if it will come out. If it does there will be an extra nut on the screw end and that needs to be removed and you need to order a new thumbscrew. That is why we call it a thumbscrew. It only has to be finger tight. The key is only for removing.
Dec 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Central unit light on a Magic delux is on Saeco
My water tank light stay's on ( can't make espresso) plus water seem's to be leaking out into tray area, also can you tell me where the filter is, and how to get to it? Helpppppppppppp!
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Temp light not on and coffee is dead cold.
I think your boiler is broken, look at www.saeco.com to locate a service center near you
Oct 28, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
721 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
