Question about Samsung HLR5067WX 50" Rear Projection HDTV
I changed the lamp on my TV because the lamp light on the front panel was blinking green to be changed but the TV makes a beeping sound and then turns off.what else could be the problem
    Genius:
  • 1,126 Answers
First thing to do is to remove the lamp and try to reinstall, and make sure everything is blown out and free of dust, the lamp and door has to be in the right position, to operate right. If that still don't work, then it could be a bad ballast board.
Posted on Oct 13, 2010
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Blinking green light
Sounds like a lamp problem itself. Anyway, if you wish to make it sure, check the site linked here. It has details about the blinking codes to Mitsubishi. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 28, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv won't turn on
change your lamp the sound will be the fans coming on if tv is a sony on some models are behind the cover on the front of tv and others are on side
Nov 29, 2009 | Televison & Video
Picture goes out after 3 seconds then may come back on then off again
If green light in front of TV blinks while picture goes off and comes back then its symptom of weak lamp that need to be replaced.
And if green light does not blink in above process then let me know.
Thanks.
Nov 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
605 people viewed this question
Henry  Thomas
Henry Thomas
