Question about Whirlpool GGW9250PL Gas Dryer
Need part number for thermistor for whirlpool Duet dryer, model number is GEW9200LW0.
  • Whirlpool Master
  • 8,220 Answers
Number 42 mounts on the blower housing right beside the thermal fuse
Need part number for thermistor for whirlpool Duet - 1ee95b6.jpgThe price is decent less than $20.
This video shows how to replace it:
Posted on Oct 13, 2010
I have a whirlpool duet gew9200lw0,it will not heat. I replaced the thermistor, thermostat,termafuse and multiple other parts and still will not heat. I need help please.
You changed all these bits without establishing whether the element was faulty? Find a local appliance engineer.
Nov 15, 2014 | Dryers
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
WHY IS MY DRYER NOT DRYING ON NORMAL CYCLE?
whirlpool dry gew9200lw0 problems is contorl locked what the solution
Jul 06, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Dec 12, 2009 | Whirlpool GEW9200L Electric Dryer
My GEW9200LW0 electric dryer will stop after a few minutes and flash E1 code. Is it most likely a faulty thermistor? How do I know the correct part # to order?
HI, the thermistor is the culprit in this situation. the actual location of the affected part is inside the unit, on the blower housing(mounted on the backside). The part number is (3976615)
E-1:=(Failed Thermistor)
SIDE NOTE:-The manufacturer has replaced part number 3976615 with this item, part number 8577274. 8577274 may differ in appearance, but is a functional equivalent to prior parts including 3976615.
Oct 21, 2009 | Whirlpool Dryers
Whirlpool GEW9200LW0 Not heating
Hi
You need to remove the back panel first then with a multi meter the easiest way is to put the meter on continuaty test (beeps when contact is made then with the dryer switched of and unplugged put one probe on the one side of the element and the other on the other side if it beeps then your element should be ok if not one of two things (1) Your element is blown or (2) there should be a fuse around the area of the back support plate it may be a normal round fuse or a ceramic round fuse or what looks like a brown rectangular piece of plastic with a wire out each side test the fuse in the same way as you tested the element if blown replace if not then put in a element.
Jan 22, 2009 | Whirlpool GEW9200L Electric Dryer
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Dryer Model GEW9200LW0-Shutting off
Guest. Your thermistor has opened, it's very easy job and inexpensive. You will have to remove the lower panel. Right behind the vent housing will be the themistor and thermal fuse. The thermistor will be the black one on the right of the thermal fuse. Kill the power, Two quarter inch screws holding it on, two wires going to it. Here's your tech sheet if the link works, http://www.servicematters.com/docs/wiring/wiring_main.htm Catriver.
Jan 13, 2008 | Whirlpool GEW9250 Electric Dryer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
549 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
