Question about Philips Computers & Internet
My philips hepc8602/05 wont load vista after a power failure i have tried using command prompts running from last known config reapiring running in safe mode any other ideas?
  • 132 Answers
Have you tried the good doctor? also you could try to use a fresh start wipe clean restart disc and start anew.
Posted on Oct 13, 2010
Wont boot/ says auto config over and over
Then use Recovery Console:
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
After restarting windows use a system utility software like RegInOut.
Dec 28, 2011 | E-Machines eMachines Desktop PC
It has a blue screen that says: STOP: c0000218 {Registry File Failure} The registry cannot load the hive (file) : \SystemRoot\System32\Config\SOFTWARE or its log or alternate. It is corrupt,...
This is a big fix and something caused your registry to become corrupted. you may have a bad hard drive, or failing RAM or infection or software issue. here is the fix for it you only need to replace the software registry hive and not the others. good luck
http://support.microsoft.com/kb/307545
Mar 03, 2011 | Computers & Internet
When i turn it on i get this screen asking how iw ant to start it, safe mode, normally, command prompt, or last known good config. any of em i entered it would boot up showing the microsoft windows XP...
this is a known problem with Windows XP. it occurs as a result of a corruption within the Registry hive.
A very thorough and complete set of instructions can be found here- http://xphelpandsupport.mvps.org/how_do_i_repair_a_stop.htm
follow the instructions to resolve your issue.
//javaftper
Aug 01, 2010 | Dell Inspiron 8100 Notebook
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
My computer froze during shut down, so I turned it off using the power button. When I start it up It gives me the options of starting normally, Last known good configuration, safe mode safe mode with...
Try go into BIOS by hitting the DEL key or F1 or F2 as you start and go to save Cmos config. then reboot.
The other approach is Last known Good config is the best. This can be brought up after presing power button then by tapping F8 till screen apears.. Select Last known Good Config
Nov 08, 2009 | Sony VAIO VGC-RA840G PC Desktop
My hp compaq c552uslaptop wont start all i get is a black screen with the following "windows error recovery" "windows failed to start a recent hardware or software change might be the cause if windows...
When you boot up your computer, press the F8 key until you get some choices such as Safe Mode and Command Prompt. There will be an option for Last Known Good Configuration. Select this and hopefully it will restore your computer settings to the way it was before this happened.
Mar 12, 2009 | Compaq Presario C552US Notebook PC
Hi, im running xp on hp compaq nx9110, power cable died and when i start it up giving me 4 options, safe mode, sm with networking, sm with command prompt. last known config or start windows normally, i...
If you cant load into any of them modes then you need to recover your computer back to its factory state, this will mean you will *lose all your data on the computer*.
If you have data then take it into a pc store or use a IDE/ATA to USB adapter to copy your data onto another computer.
But to begin the recovery on most hp's and compaqs you press F10 or F11(keep tapping till you get a beep from the pc).
When the recovery screen shows follow the on screen instructions to recover the computer
Jan 18, 2009 | Computers & Internet
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Hi, I have recently upgraded from XP to Vista 32bit SP1 and I am having problems using my soundblaster X-fi card. On boot, windows reports new hardware found and asks for the install disk. when I run the...
In many cases the hardware will not work under windows vista, although it appears to find the hardware and load the drivers etc. You may get some satisfaction by going to the website for the soundcard and looking for drivers for the card particular to vista. However it still may not work, this is a vista problem however and is one of hundreds microsoft need to sort.
Dec 07, 2008 | Asrock ConRoeXFire-eSATA2...
Laptop wont start
Dear customer
your system OS is corrupted.so please installed oprating system newly XP or VISTA.try this
Jul 25, 2008 | HP Pavilion ze4145 Notebook
Computers & Internet Logo
63 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
