Question about Fisher and Paykel GWL11 Top Load Washer
Stops mid cycle
My Fisher Paykel is about two years old. Now it stops about mid way through the wash cycle and continuously beeps until you stop it. To stop it you have to power it off and start it back up again and with this it finishes the cycle.
Any ideas?
  • Anonymous Jun 07, 2008
    Our FP washer, also two years old, beeps several times during the cycle. When we hit the Temp button and then the Start button it starts right back up. It used to do this only at the beginning when it first started a wash but lately does it thru every cycle. It's not only annoying but we're unable to use the timer function because of it. My dh says it's draining fine and we've never had an issue of standing water or flooding.  Just today it was doing this and then the entire tub/basket inside tilted to the right and stayed there. Unfortunately, we can't find the manual/cd that went with it.
    Problem Solver:
  • 7 Answers
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Posted on Jun 01, 2008
Dd603 stops mid cycle with no beeps or alarms
Please check if this happens with the short rinse cycle as well.
Also when the fast cycle stops, check if the water is cold at room temperature. Normally water temperature for wash cycles should be at leat 40deg C.
May 04, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel washing machine continually stops and beeps on spin cycle GW703. Move clothes around and continue, goes for a while and stops again, seems it is sensing it is unbalanced.
There should be a tech sheet located underneath the control panel that has a fault code matrix. Compare the lights to what you see on the sheet, and read the details.
Mar 05, 2011 | Fisher and Paykel Washing Machines
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Stops half way through rinse cycle and beeps
Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Fisher and Paykel Fisher & Paykel Washer
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
897 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
