Viore LC32V43A ,no enciende , solo enciende una luz color ambar
CAYPIANAN
  • 227 Answers
SOURCE: solo enciende, inactiva demas funciones
hola tienes que chequear la fuente de alimentacion o power supply
si abres el tv vas a ver algun capacitor que esta alterado osea como prenado cualquier pregunta me puedes enviar un mensaje a mi correo electronico\;
buena suerte
caypianan@yahoo.com
Posted on Jan 01, 2009
bbl242003
  • 1637 Answers
SOURCE: No enciende tv. La luz
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
fennectech
  • 85 Answers
SOURCE: tengo un problema antes no me daba video y se me
para solucionarlo es necesario reforzar la tarjeta de vídeo en lamáquina
apriete everytheng demás también
Posted on Jan 18, 2011
fortozo_c
  • 23 Answers
SOURCE: no enciende solo tira una
Hola:
1.- Desmonta la bateria (por debajo de la Laptop tiene, generalmente dos seguros, tira hacia afuera y se soltará la pila).
2.- Desconecta el cable de alimentación de la Laptop (eliminador).
3.- Intenta encenderla, dejando presionado el botón de encendido durante 15 - 30 segundos.
4.- Conecta solamente el cable de alimentación (sin bateria).
5.- Presiona el boton de encendido en forma normal.
Estos pasos sirven para descargar todo el circuito electrónico del equipo y/o desbloquearlo por alguna posible sobre carga eléctrica. Ve si funciona.
Si no enciende, intenta lo siguiente:
1.- Desconecta el cable de alimentación y batería.
2.- En la parte de abajo de la laptop, localiza una tapa con un ícono identificador tipo chip; desmóntala liberando el ó los tornillos.
3.- Retira el ó los módulos de memoria, jalando los seguros laterales de cada memoria. Tómala por los bordes.
4.- Limpiar o lijar los pines (contactos) de la memoria. Puedes usar un borrador de lápiz o una brocha impia y pequeña.
5.- Instalar un solo módulo de memoria, si fuera el caso.
6.- Encender la laptop sólo con el cable de alimentación.
Este procedimiento corrige una posible falla de lectura en la memoria que impide realizar el POST del equipo correctamente. Ve si funciona.
Espero y ayude. Gracias
Posted on Jan 31, 2011
  • 30 Answers
SOURCE: no reconcoce mi computador el
Suena como su computer' la impulsi?n dura de s est? quebrada. Usted debe tomarla en un taller de reparaciones de la PC para conseguirlo mirado.
Posted on Feb 05, 2011
El plato gira y la luz se enciende solo cuando se abre la puerta con la puerta cerrada el tiempo descuenta pero no calienta
Apparently there is something wrong with the door interlock or possibly the control board.
Mar 30, 2014 | GE Microwave Ovens
Da 4 head que
They did not have the Control Center software for my laptop. It did update my printer.
Aug 28, 2013 | Brother Multi-Function Center MFC-240C...
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
Por que la luz de network card esta prendida todo el tiempo color rojo a ambar es normal ? o esta fallando gracias. Dimenson 5150
La luz de la tarjeta de red se vuelven de color rojo o ?mbar si la tarjeta es mala, la tarjeta no est? conectado correctamente, o si la tarjeta no est? recibiendo una se?al de la red.
Soluciones:
1) Aseg?rese de que todos los cables se conectan correctamente desconectando ellos y conectarlos de nuevo in Compruebe que est? recibiendo una conexi?n de su proveedor de servicio.
2) Apagar el ordenador y desmontar la tarjeta de red y si es capaz de volver a montar la misma.
3) Si todo esto falla es posible que necesite obtener una nueva tarjeta de red para su equipo. Si la garant?a de Dell sigue siendo bueno debe ser capaz de obtener de Dell para reemplazar su tarjeta de red en contacto con su atenci?n al cliente.
May 23, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
No enciende solo tira una luz anaranjada atras de la carga
Hola:
Jan 31, 2011 | Acer Aspire 3680 Laptop
Televison & Video Logo
583 people viewed this question
Top Televison & Video Experts
Electro Med Services...
