Question about Canon ZR200 Mini DV Digital Camcorder
Cvideo camera turns off
Display says auto power off @ then camera turs off , why ?
  • Anonymous Nov 20, 2008
    is not battery does the same when plugged in
  • Anonymous May 17, 2009
    Seems when your videotaping or on pause for 5 minutes or longer without touching anything its a sort of power saver mode.. verry annouying.. Attempting to find out how to turn this auto power off feature off..
  • 979 Answers
Possible failed battery/low capacity. How old is the battery?
Posted on Jul 02, 2008
  • KnitRunGirl Mar 06, 2011
    The "auto power off" feature is designed to save power. There is no way to disable this feature within the Canon ZR 200's menu settings. However, you can take the MiniDV tape out of the camcorder, and this will override the auto power off. The camera will stay on if no tape is inside. You can use the camera as a web cam or to display real time camera action on a TV with the RCA video cord, without the annoying turn off after 5 minutes of inactivity.
RCA CC6262 Camcorder Problem:
check that is not just a broken cable
Jul 06, 2008 | RCA CC6262 Camcorder
When i try to turn on the camera it dosent tur on
there are some little things that you need to verify 1> see if the battery is plugged and if it is then try using another battery if this does not work take it to the seller dont forget your warranty card
Mar 03, 2011 | Panasonic NV-GS150 Mini DV Digital...
I have a hdd error when I try to record on my jvc
that is a dew sensor message /mean warm up your cam room temp press eject and get an air dryer
and blow hot air inside for a few seconds ,do not set the dryer at high level /medium or low to avoid damage to the plastic or inside it if that does nt work
you got to replace the sensor in the camera.....
Feb 25, 2010 | JVC GZ-MG175 HDD Camcorder
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Can't remember how to turn off the power save function
The auto shutdown is designed to protect the tape and heads. If you want to use it as a web cam, just remove the tape.
Apr 03, 2009 | Canon ZR60 Mini DV Digital Camcorder
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't read the date/time
There may be a simple explanation. Here are two possible reasons this is happening: * You may have disconnected the power source before turning off the power to your camcorder. If you remove the power source from the camcorder while the power is on, all settings and selections will be erased. Make sure to turn the camcorder's power off before disconnecting the power source. * This is particularly an issue for some early VHS-C camcorders – those with model numbers beginning with a "6" and ending with a "2" or "3" (i.e. CC6xx2 … CC6xx3). These camcorders have a consumer-replaceable clock battery that may be exhausted. If that battery runs dead or is removed and the main battery or AC is not connected, the camcorder will lose all its Date and Time settings. * In some models, the date and time display is designed to do this. When you turn on many VHS-C and digital camcorders, the Auto Date mode will display the time and date. When recording begins, the date is recorded on the tape for 5 seconds and then disappears. In the viewfinder, the date will then be replaced with the words AUTO DATE but they will not be recorded. They remain in your viewfinder so that you know this feature is on. On full-size or VHS camcorders, the Auto Date feature is very similar. When you first turn on the camcorder, the date along with the word AUTO and a Clock icon appear in the viewfinder. When recording begins, the date is automatically recorded for 10 seconds and then disappears. In the viewfinder, the Clock icon and the word AUTO remain but they will not be recorded. They remain so that you are aware that this feature is on. When using the Auto Date feature, be aware that the time is only recorded when you first turn on the camcorder and begin a recording session. It does not record each time you press the record button. There are a number of time and date display and recording options. Since these vary by model number, please refer to your owner’s manual for more details.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
110 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
